Please open PIO IDE Terminal and type pio update
. Does it work with new PIO Core+ 1.4.1?
Yes. Is working now
Reading symbols from c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp-wrover-kit/firmware.elf...
done.
PlatformIO Unified Debugger > http://bit.ly/pio-debug
PlatformIO: Initializing remote target...
Open On-Chip Debugger 0.10.0-dev (2018-06-04-09:51)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: BreakIn BreakOut RunStallIn
Info : accepting 'gdb' connection from pipe
Info : Target halted. PRO_CPU: PC=0x400E8E5E (active) APP_CPU: PC=0x400E8E5E
esp32: target state: halted
Info : Use core0 of target 'esp32'
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x4008B82F
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
0x400e8e5e in __udivmoddi4 (rp=0x0, d=<optimized out>, n=<optimized out>) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c:1120
1120 /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c: No such file or directory.
Not implemented stop reason (assuming exception): undefined
Error: Too large number of threads 1073511828!
Hardware assisted breakpoint 1 at 0x400e7740: file C:\Users\Calin\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, line 22.
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x400076E2
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x400076DD
wrote 16384 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.978438s (16.353 KiB/s)
** Programming Finished **
** Verify Started **
read 15088 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.331810s (44.406 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp-wrover-kit/partitions.bin in 0.642631s (6.224 KiB/s)
read 3072 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp-wrover-kit/partitions.bin and flash bank 0 at offset 0x00008000 in 0.307821s (9.746 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.792545s (10.094 KiB/s)
read 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.325811s (24.554 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x400076E0
wrote 217088 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp-wrover-kit/firmware.bin in 3.736851s (56.732 KiB/s)
read 214960 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp-wrover-kit/firmware.bin and flash bank 0 at offset 0x00010000 in 1.100367s (190.774 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
PlatformIO: Initialization completed
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
Info : Target halted. PRO_CPU: PC=0x400E7740 (active) APP_CPU: PC=0x400E8FA2
[New Thread 1073511836]
[New Thread 1073510424]
[New Thread 1073514528]
[New Thread 1073502764]
[New Thread 1073498936]
[New Thread 1073501256]
[New Thread 1073503920]
[Switching to Thread 1073509012]
Temporary breakpoint
1, app_main () at C:\Users\Calin\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp:22
22 {
Info : active_cpu: 0, changed to 1, reson = 0x8011cc11
Info : Target halted. PRO_CPU: PC=0x400D7894 APP_CPU: PC=0x400D0AE7 (active)
[New Thread 1073422388]
[Switching to Thread 1073422388]
Breakpoint
2, loop () at src\main.cpp:13
13 digitalWrite(2,!digitalRead(2));
Thanks! Do you use Zadig tool?
Yes. I set the ft2232 channel 0 to WinUSB for debug and channel 1 is using ftdi drivers (com port)
I never tested with both channels on stetted as com ports…
I know that GDB require libusb on windows for ftdi based Jtag’s.
Could you provide a screenshot here? I would like to add this information to our docs. I think it’s so useful. Also, would be thankful if you explain in a few words what need to configure.
Download and install FTDI drivers from http://www.ftdichip.com/Drivers/VCP.htm
Connect the debugger to PC USB and check the device manager to see if the drivers are installed properly:
Download Zadig tool from https://zadig.akeo.ie/
Open Zadig Tool and go to Options->List All Devices
5.Select the FT2232 channel you want to use as Jtag.
In case of Wrover-Kit, is channel 0: “Dual RS232-HS (interface 0)”, according to Wrover-Kit schematic:
If you use FT2232h minimodule, you can use any channel.
The debugger work’s with FT4232h minimodule too (tested).
In this case, you have 4 channels to chose from
It work’s even with cheap FT232x chip (ex. UM232H , UM232H-B modules).
- Select WinUSB
- Click Replace Driver
After operation completed, disconnect and reconnect the device to USB port
Now you can use PIO Debugger on ESP32
PS.
In case that other channel (channel 1 in case of wrover-kit) is not detected as com port (used by esptool for flashing),
you must enable the VCP mode on channel 1, this way:
- On device manager, right click on “USB Serial Converter B” - >Properties ->Advanced
- Select “Load VCP” then click OK.
Then, the FT2232 channel 2 should be detected as Com Port on device manager:
Wiring for Olimex JTAG debuggers
and again… back to debugger problems…
Reading symbols from c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.elf...
done.
Open On-Chip Debugger 0.10.0-dev (2018-07-24-09:39)
Info : Detected debug stubs @ 3ffc3210 on core0 of target 'esp32'
Info : Target halted. PRO_CPU: PC=0x400E649E (active) APP_CPU: PC=0x400E649E
Info : Not full dbg stub table 1 of 2
Info : Target halted. PRO_CPU: PC=0x4009170E (active) APP_CPU: PC=0x400E649E
Info : Flash mapping 0: 0x0 -> 0x0, 0 KB
Info : Flash mapping 1: 0x0 -> 0x0, 0 KB
Info : Using flash size 0 KB
0x400e649e in __udivmoddi4 (rp=0x0, d=<optimized out>, n=<optimized out>) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c:1193
1193 /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c: No such file or directory.
Error: Too large number of threads 1073511932!
Hardware assisted breakpoint 1 at 0x400e4d64: file C:\Users\Calin\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, line 22.
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x4009170E (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.905478s (17.670 KiB/s)
read 15088 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.264849s (55.633 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/partitions.bin in 0.598656s (6.682 KiB/s)
read 3072 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.267846s (11.200 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.692601s (11.551 KiB/s)
read 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.260851s (30.669 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 180224 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.bin in 3.973708s (44.291 KiB/s)
read 179344 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 0.866501s (202.124 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
Error: esp32: Faied to read insn (-4)!
Error: esp32: Faied to add SW BP!
Error: can't add breakpoint: resource not available
Warning:
Cannot insert breakpoint 2.
Cannot access memory at address 0x400d0977
- Please use triple of ` when inserting long texts. See my edit above.
- We updated openocd-esp32 to the latest version yesterday. It seems that they have introduced a bug. We will revert back to the previous version.
Yep… i found the bug:
On …/openocd\scripts\target\esp32.cfg the line
“gdb_breakpoint_override hard”
was removed.
Adding this instruction at line 100, fix the problem
PS.
Tnx for posting suggestion. I am not very familiar with this type of forum…
The latest release of OpenOCD for ESP32 is broken. We reverted back to the previous version. Please run pio update
I have problems too with my OLIMEX ARM-USB-OCD-H and Adafruit Huzzah32 (ESP-32) board.
but first I have to note that driver installation is a litte different from the example.
The first step of installing FTDI driver is not applicable to this OLIMEX debugger since :
- it does not displau as USB “Serial Converter A” or B, but as “Olimex OpenOCD JTAG ARM-USB-OCD-H”
- they explain in their documentation this:
https://www.olimex.com/Products/ARM/JTAG/_resources/ARM-USB-OCD_and_OCD_H_manual.pdf - even if you install FTDI driver it won’t work, because it doesn’t fit for OLIMEX tool.
After following driver installation process described in Olimex documentation (see chap. 3.3.3 of https://www.olimex.com/Products/ARM/JTAG/_resources/ARM-USB-OCD_and_OCD_H_manual.pdf), I wanted to start th debug session with F5.
And it gave these errors in the debug console:
Reading symbols from c:/Users/sds-emb/Documents/PlatformIO/Projects/ProjectHuzzah32Arduino/.pioenvs/featheresp32/firmware.elf...
done.
PlatformIO Unified Debugger > xxxxcensored (I can put only 2 links)
xxxcensored
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
cpu0: Current bits set: none
cpu1: Current bits set: none
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading acchi!
Info : active_cpu: 0, changed to 1, reson = 0xffffffff
Info : Target halted. PRO_CPU: PC=0x00000000 APP_CPU: PC=0x00000000 (active)
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'halt'
in procedure 'ocd_bouncer'
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
Info : Use core1 of target 'esp32'
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 7416 bytes at address 0x40090000
Error: no working area available, can't alloc space for stub code!
Error: Failed to load stub (-308)!
Error: Algorithm run faied (-308)!
Info : Auto-detected flash size 0 KB
Error: Failed to probe flash, size 0 KB
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
warning: while parsing target memory map (at line 2): Required element <memory> is missing
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1016). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 2 bytes at address 0x400E4A88
0x00000000 in ?? ()
Warn : cpu0: Failed reading 4 bytes at address 0x3FF00030
Error: Failed to read target memory (-4)!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1054). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 4 bytes at address 0x3FFC25B0
Error: Could not read FreeRTOS thread count from target
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1004). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1006). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 2 bytes at address 0x400E4CCB
Hardware assisted breakpoint 1 at 0x400e4ccb: file C:\Users\sds-emb\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, line 23.
Error: JTAG scan chain interrogation failed: all ones
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
cpu0: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
cpu1: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
Warn : cpu0: Failed reading 76 bytes at address 0x50000000
Error: esp32_soc_reset 551 err=-4
in procedure 'program_esp32'
in procedure 'reset' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 123
embedded:startup.tcl:454: Error: ** Unable to reset target **
in procedure 'program_error' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 124
at file "embedded:startup.tcl", line 454
Info : TAP esp32.cpu0 does not have IDCODE
Info : TAP esp32.cpu1 does not have IDCODE
Info : TAP auto0.tap does not have IDCODE
Info : TAP auto1.tap does not have IDCODE
Info : TAP auto2.tap does not have IDCODE
Info : TAP auto3.tap does not have IDCODE
Info : TAP auto4.tap does not have IDCODE
Info : TAP auto5.tap does not have IDCODE
Info : TAP auto6.tap does not have IDCODE
Info : TAP auto7.tap does not have IDCODE
Info : TAP auto8.tap does not have IDCODE
Info : TAP auto9.tap does not have IDCODE
Info : TAP auto10.tap does not have IDCODE
Info : TAP auto11.tap does not have IDCODE
Info : TAP auto12.tap does not have IDCODE
Info : TAP auto13.tap does not have IDCODE
Info : TAP auto14.tap does not have IDCODE
Info : TAP auto15.tap does not have IDCODE
Info : TAP auto16.tap does not have IDCODE
Info : TAP auto17.tap does not have IDCODE
Info : TAP auto18.tap does not have IDCODE
Warn : Unexpected idcode after end of chain: 21 0x00000000
Warn : Unexpected idcode after end of chain: 53 0x00000000
Warn : Unexpected idcode after end of chain: 85 0x00000000
Warn : Unexpected idcode after end of chain: 117 0x00000000
Warn : Unexpected idcode after end of chain: 149 0xfffffff8
Error: double-check your JTAG setup (interface, speed, ...)
Info : JTAG tap: esp32.cpu0 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu0 UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu0 expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32.cpu1 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu1 UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu1 expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: auto0.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto1.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto2.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto3.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto4.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto5.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto6.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto7.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto8.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto9.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto10.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto11.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto12.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto13.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto14.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto15.tap tap/device found: 0x7fffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0x7)
Warn : Unexpected idcode after end of chain: 580 0x00000002
Warn : Unexpected idcode after end of chain: 612 0x00000000
Warn : Unexpected idcode after end of chain: 644 0x00000000
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (2020). Workaround: increase "set remotetimeout" in GDB
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1011). Workaround: increase "set remotetimeout" in GDB
Error: Exception reading pc!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1015). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1001). Workaround: increase "set remotetimeout" in GDB
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Info : active_cpu: 1, changed to 0, reson = 0xffffffff
Program received signal
SIGINT, Interrupt.
0x00000000 in ?? ()
while OLIMEX tool Led is blinking
After that I tried to put some breakpoints, an push starts, nothing happens, the blinky arduino code doesn’t even make the led blink on the board.
I had the following error messages on the debug console:
Warn : xtensa_read_memory: esp32: target not halted
Warn : WARNING! The target is already running. All changes GDB did to registers will be discarded! Waiting for target to halt.
Info : Halt timed out, wake up GDB.
Warn : target esp32 is not halted
Error: FreeRTOS_update_threads not TARGET_HALTED!
Remote target] #1 stopped.
0x00000000 in ?? ()
And the Olimex tool led is still blinking
My hardware set up is Windows 8.1, VSCode (last version), pio core version 3.6.1a1
And the hardware wiring is the one described here : Debugging ESP32 · Pro/open62541-arduino Wiki · GitHub
*** UPDATE1 ***
After two or tree tries my Adafruit HUZZAH32 has stopped to work, I can not even upload the simple blinky example to normal process: The PC does not even detect the board !!!
More details: Since there is already Blinky programm in it, when I plug it in my PC (or a powered USB hub) it blinks 1 or 2 secs, then it stops and the board warms up.
*** UPDATE2 *** Update after a last retry, the CP2104 component burnt ! I can’t programm the Adafruit board trough USB anymore !
I think however that the target is still programmable via JTAG controller (if it is correctly wired). Correct me if I’m wrong.
Yes. It can be programmed by Jtag.
-Make sure the Jtag is connected correctly to the target board.
-Make sure you set on platformio.ini “debug_tool = olimex-arm-usb-ocd-h” or “debug_tool = ftdi”
I never tested platformio with olimex jtag… but it should work like any other ftdi based jtag.
Still, i recommend using the zadig solution for the driver. Is tested and working.
Zadig is recommended inside the documentation protocol of the Olimex tool so I used Zadig.
I didn’t succed into programming it via the JTAG, I don’t know if the wiring is correct, I didn’t find any documentation which explain how to connect it exept that link I gave above. I’ve noticed him about what happened and he answered:
Thanks for the info, but as always with microcontroller programming: You really have to know what you are doing. There can be many reasons why your board broke. The only think I know for sure is that the procedure worked for me. Note that I did not use platform.io at all…
Yes, but there is no information in Adafruit website of where are the pins of JTAG debugging on their Adafruit Huzzah32 board
So I based myself on this schema below from this tutorial (next link): Debugging ESP32 · Pro/open62541-arduino Wiki · GitHub
Use 'Pio Debug" and platformio will compile the project, upload to target using Jtag, then will start the debug session.
Please take a look at hint on your screenshot. AVAILABLE: ....
, CURRENT: ...
, upload_protocol = ...
http://docs.platformio.org/en/latest/projectconf/section_env_upload.html#upload-protocol
