and again… back to debugger problems…
Reading symbols from c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.elf...
done.
PlatformIO Unified Debugger > http://bit.ly/pio-debug
Open On-Chip Debugger 0.10.0-dev (2018-07-24-09:39)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : Detected debug stubs @ 3ffc3210 on core0 of target 'esp32'
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: BreakIn BreakOut RunStallIn
Info : Target halted. PRO_CPU: PC=0x400E649E (active) APP_CPU: PC=0x400E649E
Info : Not full dbg stub table 1 of 2
Info : Target halted. PRO_CPU: PC=0x4009170E (active) APP_CPU: PC=0x400E649E
Info : Flash mapping 0: 0x0 -> 0x0, 0 KB
Info : Flash mapping 1: 0x0 -> 0x0, 0 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 0 KB
0x400e649e in __udivmoddi4 (rp=0x0, d=<optimized out>, n=<optimized out>) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c:1193
1193 /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libgcc/libgcc2.c: No such file or directory.
Not implemented stop reason (assuming exception): undefined
Error: Too large number of threads 1073511932!
Hardware assisted breakpoint 1 at 0x400e4d64: file C:\Users\Calin\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, line 22.
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x4009170E (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.905478s (17.670 KiB/s)
** Programming Finished **
** Verify Started **
read 15088 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.264849s (55.633 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/partitions.bin in 0.598656s (6.682 KiB/s)
read 3072 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.267846s (11.200 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.692601s (11.551 KiB/s)
read 8192 bytes from file C:/Users/Calin/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.260851s (30.669 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 180224 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.bin in 3.973708s (44.291 KiB/s)
read 179344 bytes from file c:/Users/Calin/Documents/PlatformIO/Projects/esp32_blink/.pioenvs/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 0.866501s (202.124 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
Error: esp32: Faied to read insn (-4)!
Error: esp32: Faied to add SW BP!
Error: can't add breakpoint: resource not available
Warning:
Cannot insert breakpoint 2.
Cannot access memory at address 0x400d0977
