Error in Debug Console when start debugging (ESP32)
Hi all,
I’m trying to debug using an ESP-prog and a ESP32 and it is not working.
I get the following in the debug console when I click start debuggging:
Processing lolin32 (platform: espressif32; framework: arduino; board: lolin32)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin32.html
PLATFORM: Espressif 32 1.9.0 > WEMOS LOLIN32
 - framework-arduinoespressif32 2.10002.190628 (1.0.2)
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\lolin32\firmware.elf
Checking size .pio\build\lolin32\firmware.elf
RAM:   [          ]   4.1% (used 13460 bytes from 327680 bytes)
Flash: [==        ]  15.1% (used 198512 bytes from 1310720 bytes)
========================= [SUCCESS] Took 2.04 seconds =========================
undefinedError: Traceback (most recent call last):
  File "c:\users\brian\.platformio\penv\lib\site-packages\platformio\__main__.py", line 102, in main
    cli()  # pylint: disable=no-value-for-parameter
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\core.py", line 764, in __call__
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\core.py", line 717, in main
    rv = self.invoke(ctx)
  File "c:\users\brian\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
    return super(PlatformioCLI, self).invoke(ctx)
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\core.py", line 1137, in invoke
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\core.py", line 956, in invoke
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\core.py", line 555, in invoke
    return callback(*args, **kwargs)
  File "c:\users\brian\.platformio\penv\lib\site-packages\click\decorators.py", line 17, in new_func
  File "c:\users\brian\.platformio\penv\lib\site-packages\platformio\commands\debug\command.py", line 151, in cli
    from platformio.commands.debug.client import GDBClient, reactor
  File "c:\users\brian\.platformio\penv\lib\site-packages\platformio\commands\debug\client.py", line 34, in <module>
    from platformio.commands.debug.server import DebugServer
SyntaxError: 'return' with argument inside generator (server.py, line 121)
I’ve installed the ESP-prog drivers as per this link:
I’m using a shield for connecting the ESP-prog to the ESP32 (D1 mini style one). I’ve used this shield before so I know the wiring is ok.
I’m using the latest version of PlatformIO (Core4.3) from the Visual studio code extension installer. I’m on Windows 10
Any suggestion to what I can try?
Thanks
Brian
Looking at [v0.1.20/py2.7] SyntaxError: 'return' with argument inside generator · Issue #46 · asweigart/pyscreeze · GitHub and Python SyntaxError: ("'return' with argument inside generator",) - Stack Overflow it may be related to the Python version. When opening a PIO terminal, what Python version are you running or have you installed in the system?
Also, are all packages updated (pio platforms update)?
Hey Max, Thanks for the reply, when I run python --version in the pio terminal I get
Python 2.7.13
Running pio platform update did update some things, but the error persists.
One thing that might be worth mentioning is that I previously had a PIO install on this machine and delete VScode so I could go through the setup process again for a video, so im not sure if I left it in a bad state or whatever. If you suggest starting fresh could you please advise if there are steps for completely removing the pio install?
Check:
python3 --version
I think you need at least 3.3, but I’m using 3.7.5 on Linux.
This is a bug on our side with Python 2.7 and has been just fixed in Fixed an error "SyntaxError: 'return' with argument inside generator"… · platformio/platformio-core@6b2ff04 · GitHub
Please upgrade to the development version of PIO Core via pio upgrade --dev or install Python 3, remove c:\users\***\.platformio\penv folder and restart VSCode.
We plan to issue a hotfix PIO Core 4.3.1 release soon. Sorry for the issue.
Thank you @ivankravets, will check it out after work.
I updated to dev and it worked, thank you!
