Open On-Chip Debugger v0.10.0-esp32-20201202 (2020-12-02-17:38)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
2
Info : FreeRTOS creation
adapter speed: 5000 kHz
I’m not sure why one would need to install the official VCP drivers if they’re immediately overloaded by using Zadig + libusb… Did you just try Zadig?
In the Windows device manager, you can manually right-click on a device (here it should be the FTDI USB device) → “Update Driver” → select manual directory → point to the above folder. The inf and cat files are the driver description files
I have tried libusb with zadig, did not change the error, and then I tried updating the drivers for the ones I downloaded (ftdi), and it sais The best drivers are already installed…
Looking for upload port...
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
*** [upload] Explicit exit, status 1
How do I reverse the installation?? I could always use the upload_port parameter but I liked when it found it automatically
I reverted the changes in the driver ettings in device manager, but now I get this error when uploading
Uploading .pio\build\esp-wrover-kit\firmware.bin
esptool.py v3.0
Serial port
File "C:\Users\jcbsk\.platformio\packages\tool-esptoolpy\esptool.py", line 3969, in <module>
_main()
File "C:\Users\jcbsk\.platformio\packages\tool-esptoolpy\esptool.py", line 3962, in _main
main()
File "C:\Users\jcbsk\.platformio\packages\tool-esptoolpy\esptool.py", line 3551, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:\Users\jcbsk\.platformio\packages\tool-esptoolpy\esptool.py", line 271, in __init__
self._port = serial.serial_for_url(port)
File "c:\users\jcbsk\.platformio\penv\lib\site-packages\serial\__init__.py", line 90, in serial_for_url
instance.open()
File "c:\users\jcbsk\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 64, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port '': FileNotFoundError(2, 'The system cannot find the path specified.', None, 3)
*** [upload] Error 1
======================================== [FAILED] Took 6.30 seconds ========================================
The terminal process "C:\Users\jcbsk\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
What kind of hardware do you use for debugging? Do you have a debug adapter like ESP-Prog or a separate FTDI board?
Your device manager screenshot shows that you have configured Silicon Labs CP2102N chip for libusb. This is USB-to-serial chip often found on ESP32 development board. This chip is used for the serial connection only and not suitable for debugging. But there might be additional devices not shown in your screenshot.
As far as I can tell, you have a simple development board without debug adapter. The ESP-WROVER-KIT would look like this:
In order to debug your board, you will need to buy some sort of debug adapter, either a simple break-out board with an FTDI FT2232HL chip, an ESP-Prog or one of the supported JTAG adapters. Also see:
