How to post logs and code in PlatformIO Community Forum
To make your protocol or source code easier to read, please use pre-formatted text (</> icon in the toolbar).
  1. Copy your source code or your protocol.
  2. Then click on the </> icon and paste your code.
Example: Content from a source code file
Without pre-formatted text:
Serial.println(“Hello World!”);
void loop() {}
Using pre-formatted text:
  Serial.println("Hello World!");
void loop() {}
Example: error log
src/main.cpp: In function ‘void setup()’:
src/main.cpp:3:5: error: ‘Serial’ was not declared in this scope
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
src/main.cpp: In function 'void setup()':
src/main.cpp:3:5: error: 'Serial' was not declared in this scope
Example: Content from a platformio.ini file
Apart from being much more readable when formatted in this way, it prevents “strange” effects in the browser with:
  • Some text lines appearing in massive text for no reason.
  • The Windows backslash character, '\', in filenames, causes the following character to be treated as a control character or omitted from the text altogether.
  • Etc.
Cheers,
Norm.
I can’t find the </> symbol in the tool bar. Am I looking in the wrong place or do I need to install something additional?
It only shows up once you hit the “Reply” Button
Right next to the " symbol
You can also use the keyboard shortcut ctrl+e.
