I searched this topic and found two topics, which remained unanswered… my problem is pretty much the same.
I am running VScode 1.43.2 on Linux Mint 18.3 Sylvia, and PlatformIO, version 4.3.1.
I have a simple Arduino sketch that uses Mouse.h, however, it does not compile due to Mouse.h not found.
My platformio.ini:
[platformio]
default_envs = sparkfun_promicro16
[env:sparkfun_promicro16]
board = sparkfun_promicro16
lib_deps = Mouse
The Terminal says:
# [2020-04-15 18:01] maxg@maxg-pc-mint /media/maxg/Data SSD/Data/Workspaces/PlatformIO/Projects/MouseSim_v1 $
pio run -t upload -v
Processing sparkfun_promicro16 (platform: atmelavr; board: sparkfun_promicro16; lib_deps: Mouse)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sparkfun_promicro16.html
PLATFORM: Atmel AVR 2.0.0 > SparkFun Pro Micro 5V/16MHz
HARDWARE: ATMEGA32U4 16MHz, 2.50KB RAM, 28KB Flash
- tool-avrdude 1.60300.190424 (6.3.0)
Framework incompatible library /home/maxg/.platformio/lib/EmonLib_ID116
Framework incompatible library /home/maxg/.platformio/lib/Ethernet_ID872
Framework incompatible library /home/maxg/.platformio/lib/Mouse_ID890
Framework incompatible library /home/maxg/.platformio/lib/OneWire_ID1
Framework incompatible library /home/maxg/.platformio/lib/PubSubClient_ID89
Framework incompatible library /home/maxg/.platformio/lib/RF24_ID433
Framework incompatible library /home/maxg/.platformio/lib/USBHost_ID885
Framework incompatible library /home/maxg/.platformio/lib/WiFiEsp_ID509
Framework incompatible library /home/maxg/.platformio/lib/WiFi_ID870
Framework incompatible library /home/maxg/.platformio/lib/cactus_io_BME280_I2C
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 0 compatible libraries
avr-g++ -o .pio/build/sparkfun_promicro16/src/main.o -c -Wno-error=narrowing -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DPLATFORMIO=40301 -DARDUINO_AVR_PROMICRO16 -Iinclude -Isrc src/main.cpp
I got this result, before I installed the Mouse library, and after I installed it.
The program I am running works in the Arduino IDE I specifically installed for this test (and was never installed on this machine before). I downloaded the Sparkfun library for the Micro Pro board, 16bit, 5V.
Reading the other two threads above do not provide any hits or solution. Any help appreciated… as it seems rather nonsensical to use PlatformIO for all my UNO developments, but not for the Micro Pro.
