In Platformio every code i upload to my Arduino Micro Pro works except this one:
#include <Arduino.h> #include <Mouse.h>
int horzPin = A0; // Analog output of horizontal joystick pin
int vertPin = A1; // Analog output of vertical joystick pin
int selPin = 9; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 200; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
void setup()
Serial.begin(9600);
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
if (vertValue != 0)
Mouse.move(0, vertValue/sensitivity, 0); // move mouse on y axis
Serial.print(vertValue);
if (horzValue != 0)
Mouse.move((horzValue/sensitivity) *-1, 0, 0); // move mouse on x axis
Serial.print(horzValue);
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
else if ((digitalRead(selPin))&&(mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
This same code works if i upload it through Arduino IDE.
In Platformio i use pio run -t upload to upload the code, the command pio run -t program does not work because i don’t have an external programmer, my Arduino is connected directly via usb port to the PC.
Platformio uploads the code without errors, testing with Serial.print() i can see the values of vertValue and horzValue changing via serial monitor when i move the joystick, but my mouse is not moving.
I compared the library Mouse.h from Platformio library with the Mouse.h from Arduino IDE library and they are identical.
Why this same code works via Arduino IDE and doesn’t work via Platformio???
Sorry for take too long, it’s because my board has fried and i had to get a new one, as you can see, the Mouse is from C:\Users\Beto\Documents\PlatformIO\Projects\KeyboardMouseControl.pio\libdeps\micro\Mouse_ID890
And here is the upload command with the --verbose option:
Processing micro (platform: atmelavr; framework: arduino; board: micro; lib_deps: Mouse)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/micro.html
PLATFORM: Atmel AVR 1.15.0 > Arduino Micro
HARDWARE: ATMEGA32U4 16MHz, 2.50KB RAM, 28KB Flash
PACKAGES: toolchain-atmelavr 1.50400.190710 (5.4.0), framework-arduinoavr 4.1.2, tool-avrdude 1.60300.190424 (6.3.0)
Found 7 compatible libraries
|-- <Mouse> 1.0.1 (C:\Users\Beto\Documents\PlatformIO\Projects\KeyboardMouseControl\.pio\libdeps\micro\Mouse_ID890)
| |-- <HID> 1.0 (C:\Users\Beto\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\HID)
avr-g++ -o .pio\build\micro\firmware.elf -Os -mmcu=atmega32u4 -Wl,--gc-sections -flto -fuse-linker-plugin .pio\build\micro\src\main.cpp.o -L.pio\build\micro -Wl,--start-group .pio\build\micro\lib488\libHID.a .pio\build\micro\libf25\libMouse_ID890.a .pio\build\micro\libFrameworkArduinoVariant.a .pio\build\micro\libFrameworkArduino.a -lm -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pio\build\micro\firmware.elf"])
DATA: [= ] 8.2% (used 211 bytes from 2560 bytes)
PROGRAM: [== ] 19.9% (used 5716 bytes from 28672 bytes)
.pio\build\micro\firmware.elf :
section size addr
.data 50 8388864
.text 5666 0
.bss 161 8388914
.comment 48 0
.note.gnu.avr.deviceinfo 64 0
.debug_info 2548 0
.debug_abbrev 2410 0
.debug_line 26 0
.debug_str 881 0
Total 11854
<lambda>(["upload"], [".pio\build\micro\firmware.hex"])
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
BeforeUpload(["upload"], [".pio\build\micro\firmware.hex"])
Auto-detected: COM17
Forcing reset using 1200bps open/close on port COM17
Waiting for the new upload port...
avrdude -v -p atmega32u4 -C C:\Users\Beto\.platformio\packages\tool-avrdude\avrdude.conf -c avr109 -b 57600 -D -P "COM13" -U flash:w:.pio\build\micro\firmware.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\Beto\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : COM13
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: reading input file ".pio\build\micro\firmware.hex"
avrdude: writing flash (5716 bytes):
Writing | ################################################## | 100% 0.50s
avrdude: 5716 bytes of flash written
avrdude: verifying flash memory against .pio\build\micro\firmware.hex:
avrdude: load data flash data from input file .pio\build\micro\firmware.hex:
avrdude: input file .pio\build\micro\firmware.hex contains 5716 bytes
Reading | ################################################## | 100% 0.09s
avrdude: verifying ...
avrdude: 5716 bytes of flash verified
avrdude: safemode: Fuses OK (E:CB, H:D8, L:FF)
avrdude done. Thank you.
===================================================================================================== [SUCCESS] Took 5.83 seconds =====================================================================================================
No, the library was downloaded automatically from platformio when i upload the project to the board, as you can see platformio put the library in the libdeps folder of the project:
PS: The lib_archive = false in platformio.ini didn’t work.
