Hi https://community.platformio.org/u/sivar2311
Yes (onEvent), sorry it was a typo, my fault!
After clearing out of all Monday morning meetings I was able to upload, after doing the button reset sequence, therefore solving with it my upload problem. Thanks!
After setting ARDUINO_USB_CDC_ON_BOOT=0 I was able to upload without doing the button reset sequence too.
The problem I am having now and after a couple of hours of searching for a solution without success, is that the native debugger is now misbehaving. It will not stop at the breakpoints and if I stop it manually (pause) and restart it (play) it will not stop even when the breakpoint is in the loop() routine.
This happens with ARDUINO_USB_CDC_ON_BOOT=0 and with =1.
I even tryed to lower debug_speed = 500 as suggested in some posts with no better result.
The output of the debug console is (sorry for the length):
undefinedC:\Users\tmagdahl\.platformio\packages\toolchain-xtensa-esp32s3\bin\xtensa-esp32s3-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from c:\Data\Project\Guardian\NewPCB_2\Code\PIO\Test\TestDevKit_01\TestDevKit_01\.pio\build\esp32-s3-devkitc-1-n8r2\firmware.elf...
PlatformIO: debug_tool = esp-builtin
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
adapter speed: 40000 kHz
Warn : Transport "jtag" was already selected
adapter speed: 500 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : esp_usb_jtag: serial (DC:DA:0C:61:9E:3C)
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 500 kHz
Info : JTAG tap: esp32s3.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32s3.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : [esp32s3.cpu0] Debug controller was reset.
Info : [esp32s3.cpu0] Core was reset.
Error: Unexpected OCD_ID = 00000000
Warn : target esp32s3.cpu1 examination failed
Info : starting gdb server for esp32s3.cpu0 on pipe
Info : [esp32s3.cpu0] Target halted, PC=0x40041A79, debug_reason=00000000
Info : Set GDB target to 'esp32s3.cpu0'
Warn : No symbols for FreeRTOS!
Info : [esp32s3.cpu0] Target halted, PC=0x403B2482, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3c030020, 54 KB
Info : Flash mapping 1: 0x20020 -> 0x42000020, 164 KB
Info : Auto-detected flash bank 'esp32s3.cpu0.flash' size 8192 KB
Info : Using flash bank 'esp32s3.cpu0.flash' size 8192 KB
Info : Using flash bank 'esp32s3.cpu0.irom' size 168 KB
Info : Using flash bank 'esp32s3.cpu0.drom' size 56 KB
Info : New GDB Connection: 1, Target esp32s3.cpu0, state: halted
Warn : negative reply, retrying
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1817 ms). Workaround: increase "set remotetimeout" in GDB
0x40041a79 in ?? ()
Error: FreeRTOS maximum used priority is unreasonably big, not proceeding: 246
Info : [esp32s3.cpu0] requesting target halt and executing a soft reset
Info : [esp32s3.cpu0] Target halted, PC=0x500000EF, debug_reason=00000000
Info : [esp32s3.cpu1] requesting target halt and executing a soft reset
Error: Target not examined yet
Info : [esp32s3.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32s3.cpu1] Debug controller was reset.
Info : [esp32s3.cpu1] Core was reset.
Info : [esp32s3.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (3516 ms). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (3327 ms). Workaround: increase "set remotetimeout" in GDB
Info : Auto-detected flash bank 'esp32s3.cpu1.flash' size 8192 KB
Info : Using flash bank 'esp32s3.cpu1.flash' size 8192 KB
** Programming Started **
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (3166 ms). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1018 ms). Workaround: increase "set remotetimeout" in GDB
Info : PROF: Erased 16384 bytes in 1017.36 ms
Info : PROF: Data transferred in 701.125 ms @ 22.8205 KB/s
Info : PROF: Wrote 16384 bytes in 1815.95 ms (data transfer time included)
** Programming Finished in 14334 ms **
** Verify Started **
Info : PROF: Flash verified in 934.062 ms
** Verify OK **
** Verify OK **
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (3169 ms). Workaround: increase "set remotetimeout" in GDB
Info : PROF: Erased 4096 bytes in 938.725 ms
Info : PROF: Data transferred in 184.693 ms @ 21.6576 KB/s
Info : PROF: Wrote 4096 bytes in 1278.48 ms (data transfer time included)
** Programming Finished in 6735 ms **
Info : PROF: Flash verified in 923.968 ms
** Verify OK **
** Verify OK **
Info : PROF: Erased 8192 bytes in 967.331 ms
Info : PROF: Data transferred in 334.935 ms @ 23.8852 KB/s
Info : PROF: Wrote 8192 bytes in 1432.59 ms (data transfer time included)
** Programming Finished in 6917 ms **
Info : PROF: Flash verified in 929.185 ms
** Verify OK **
** Verify OK **
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1362 ms). Workaround: increase "set remotetimeout" in GDB
Info : PROF: Erased 299008 bytes in 1866.29 ms
Info : PROF: Data transferred in 12167.2 ms @ 23.9989 KB/s
Info : PROF: Wrote 299008 bytes in 13355.2 ms (data transfer time included)
** Programming Finished in 19745 ms **
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1049 ms). Workaround: increase "set remotetimeout" in GDB
Info : PROF: Flash verified in 1088.9 ms
** Verify OK **
** Verify OK **
Hardware assisted breakpoint 1 at 0x420039ec: file C:/Users/tmagdahl/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp, line 56.
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (9383 ms). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (6052 ms). Workaround: increase "set remotetimeout" in GDB
Warn : negative acknowledgment, but no packet pending
It seems the problem could be solved with Workaround: increase "set remotetimeout" in GDB
I have been searching on how to “set remotetimeout” to something longer but every related post ends up diverting for a different solution with other issues, to the point that I have not been able to even find where gdb’s remotetimeout can be inspected.
Even searched at the Help-->Show all Commands textbox with no success.
Now, maybe I tackled things in the wrong order and as a first, I had to do the “Arduino Framework 2.x.x, which was fixed with version 2.0.17” upgrade, but I had no idea from where to make it (I notice there is a ZIP file and a couple of JSON files) so I do not wreck my now working environment.
So to put things clear and in perspective (here we say that the “excellent” is the enemy of the “good”), by keeping ARDUINO_USB_CDC_ON_BOOT=1 and ARDUINO_USB_MODE=0, I am more than satisfied as adding a delay after Serial.begin() is more than adequate for my actual needs.
