Debugging a teensy with Platformio vscode plugin
Update
I read in one place that the teensy 4.1 has debugging capability built in and elsewhere that 4.1 requires an extra bit of hardware. Can you clarify?
I seem to have made progress. I am using the plartformio vscode plugin successfully. I am able to build and upload. When I click on ‘debug’ I see some packages being recompiled, and something being uploaded. Buit after a moment of showing activity, the debug plug in stops and it looks like nothing is happening.
Do I have to modify my code and put in, for example, debug.start() or something like that?
Can someone shed some light on this?
Original
I have never done this before. Reading the help it seems to imply that I need an extra bit of hardware. In other words the simple usb connection from myraspberry pi to the teensy won’t be sufficient for debugging. Is that correct?
Hi @pitosalas,
That’s correct, it’s not possible to debug the Teensy 4.1 board even with additional hardware. Although, some developers use a GDB stub as a workaround GitHub - ftrias/TeensyDebug: GDB proxy and debugging support to Teensy 3/4
Thanks. I do wonder then why Platformio (vs code IDE) has a debug task, which does a lot of recoiling and reuploading, but in the end doesn’t do anything. You would think there would be a simple error message somewhere.
Or are those commands meant to work with the GDB proxy?
I guess here’s the high level question: do most people programming Teensy with Platformio just do print statements to debug?
Also do Arduino type debuggers give better debugging support?
Thanks!
That’s probably a mistake in the board manifest, there is no easy way to debug this board.
I believe so.
I’m not sure what debuggers you mean, it’s a limitation imposed by the hardware.
Let’s say I switch from the teensy to one of the several Arduino or similar SBC. And I continue to use PlatformIO for deploying. Would the debug features be usable without additional special hardware? (The most important debug features are setting breakpoints, stepping and examing variables.) Which Arduino-family boards would you recommend?
It is not an “Arduino family” board but the ESP32-S3 has a built-in debugger.
See the great article by eduardogb: How to use JTAG built-in debugger of the ESP32-S3 in PLATFORMIO
Very technically, the Teensy 4 is hardware-debuggable if you have extreme skills in microsoldering and an external debug probe like a J-Link:
You should use the exact platformio.ini as provided in that project.
Hi @valeros and @maxgerhardt,
Greetings!
I use PlatformIO VSCode Plugin for my Teensy 4.0 setup and was able to successfully compile and upload. Now, I am in need of the Debug option and unfortunately I couldn’t succeed with it. Below explains the scenario:
  1. Using Teensy 4.0 for SPI Master-Slave Communication and using the same examples of this library GitHub - tonton81/SPI_MSTransfer_T4.
  2. Updated the platform.ini file as provided in GitHub - ftrias/TeensyDebug: GDB proxy and debugging support to Teensy 3/4 and updated the debug_port as I am using Windows. See below:
[env:teensy40]
platform = teensy
board = teensy40
; change microcontroller
board_build.mcu = imxrt1062
build_type = debug
; See https://github.com/platformio/platform-teensy/issues/65
build_unflags = -DUSB_SERIAL
build_flags = -DUSB_DUAL_SERIAL
debug_port = \\.\COM10
debug_tool = custom
debug_load_mode = manual
debug_server =
debug_init_cmds =
  target extended-remote $DEBUG_PORT
  $INIT_BREAK
  define pio_reset_run_target
  interrupt
  tbreak loop
  continue
  end
  define pio_restart_target
  echo Restart is undefined for now.
  end
debug_init_break =
  1. I am able to compile the Master example MASTER.ino
    (Note: Added below as well to the code).
    #include “TeensyDebug.h”
    #pragma GCC optimize (“O0”)
    After a normal upload, I do not see anything if I start the PIO Debug. I see the console opens but shouldn’t it stop if I sent a normal breakpoint in Vscode? Sorry if my understanding is wrong.
  2. Similarly, It tried the Slave code SPI_MSTransfer_SLAVE.ino. Unfortunately, it fails the compilation. If I revert the platformio.ini file it compiles successfully.
  3. FYR: I downloaded and kept the TeensyDebug-master folder from GitHub under my project lib directory.
I would really appreciate if you could guide me here for integrating this debug feature to my project . I do also have a doubt regarding the usage of this debug feature, like can I directly follow normal breakpoint setting as in VSCode or do I have to create/include some setup and other debug commands in my main.cpp?
Thanks
Anand
