A brief desciption of my situation:
I want to debug a Atmel ATmega 328P using an AVR Dragon. The hardware is working: I can successfully initiate a debugging session in Atmel Studio. I can also start a debug session using avarice (on linux), gdb and step through the code.
The debugger of PlatformIO (VSCode) is also working (albeing it not as stable as the previous two), but not on CLion. When the debug session is starting, the debugger is stuck on ‘Loading’ in the Thread-1 pane and ‘Collecting data’ on the Variables pane. After a few seconds, it crashes (or at least, the debug session stops, avarice keeps running in the background). A debug log:
Preparing firmware for debugging...
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.1.0) > Arduino Uno
DEBUG: Current (custom) On-board (avr-stub, simavr)
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Building in debug mode
Checking size .pio/build/uno/firmware.elf
RAM: [= ] 11.4% (used 234 bytes from 2048 bytes)
Flash: [= ] 8.2% (used 2632 bytes from 32256 bytes)
========================= [SUCCESS] Took 0.27 seconds =========================
Reading symbols from /home/WirePirate/CLionProjects/untitled/.pio/build/uno/firmware.elf...done.
PlatformIO: debug_tool = custom
0x00000000 in __vectors ()
warning: Can not parse XML memory map; XML support was disabled at compile time
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
And my platformio.ini:
[env:uno]
board = uno
upload_protocol = dragon_isp
upload_flags = "-e"
board_upload.require_upload_port = false
debug_server =
avarice
--dragon
--debugwire
:4242
debug_tool = custom
debug_port = :4242
debug_init_cmds =
target remote $DEBUG_PORT
debug_load_cmds =
file "$PROG_PATH"
file /home/WirePirate/CLionProjects/untitled/.pio/build/uno/firmware.elf
load
This is the same config used to run the debug session in VSCode. If anyone has a hint, I’m eager to hear it. Since it is even working in VSCode, this is propably a PlatformIO bug.
