Why are ESP32-S3 boards' RAM size set to 320 KB?
My project uses ESP32-S3 N16R8 with Arduino SDK, and the maximum_ram_size in the board definition file makes me somewhat confused. The definition json reference:
Yes, this file works. But I am wondering that, is it not that ESP32-S3 have 512 KB SRAM according to datasheet than 320 KB written in json file? Why is the value not 524288, or am I missing something here? Thanks.
That’s following exactly what Arduino-ESP32 made by Espressif does:
Note that 512K describes the total SRAM, but it’s split in DRAM (data-bus), IRAM (instruction-bus), RTC Fast memory, RTC slow memory, etc., so not equally usuable. And there’s also the flash cache playing a part in it. You can see the exact memory partitionning done at the linker file.
The link in reply above, “the linker file”, is broken.
Take the file from the branch release/v2.x:
