Can you try the following: Create a new folder called boards
in the project directory. Fill it with the file esp32s3dev.json
with content
"build": {
"arduino":{
"ldscript": "esp32s3_out.ld",
"memory_type": "opi_opi"
"core": "esp32",
"extra_flags": [
"-DARDUINO_RUNNING_CORE=1",
"-DARDUINO_EVENT_RUNNING_CORE=1",
"-DBOARD_HAS_PSRAM",
"-DESP32S3_DEV",
"-DARDUINO_USB_MODE=1",
"-DARDUINO_USB_CDC_ON_BOOT=1"
"f_cpu": "240000000L",
"f_flash": "80000000L",
"flash_mode": "dout",
"hwids": [
"0X303A",
"0x1001"
"mcu": "esp32s3",
"variant": "esp32s3"
"connectivity": [
"wifi",
"bluetooth"
"debug": {
"openocd_target": "esp32s3.cfg"
"frameworks": [
"arduino"
"name": "Espressif ESP32-S3 Dev Module",
"upload": {
"flash_size": "4MB",
"maximum_ram_size": 327680,
"maximum_size": 4194304,
"require_upload_port": true,
"speed": 921600
"url": "https://www.adafruit.com/product/5290",
"vendor": "Espressif"
(and yes, dout
mode for OPI 80MHz selection shuold be correct per this).
Then use the platformio.ini
[env:esp32s3dev]
board = esp32s3dev
and try to run some basic blinky or serial program.
