I use PlatformIO in VS Code with the espidf and Arduino framework. Please take a look at my platformio.ini`:
[platformio]
src_dir = src
[env]
# Use esp-idf version 3.40001.200521
platform = espressif32@1.12.4
framework = arduino, espidf
# 4 MB module version
board_upload.flash_size = 4MB
board_upload.maximum_size = 4194304
board_build.partitions = partitions_4MB.csv
upload_speed = 921600
upload_port = COM4
monitor_port = COM4
platform_packages =
framework-arduinoespressif32 @ https://github.com/marcovannoord/arduino-esp32.git#idf-release/v4.0
toolchain-xtensa32@3.80200.200512
extra_scripts =
pre:scripts/Clean.py
[common]
# ESP32 specific (used by different libraries i. e. BLE)
-D ESP32
-D ARDUINO_ARCH_ESP32
-D ARDUINO_ESP32_DEV
# Only needed for ESP32 rev v1
#-mfix-esp32-psram-cache-issue
# Used for ArduinoJSON
-D ARDUINOJSON_ENABLE_ARDUINO_STRING=1
lib_deps_builtin =
lib_deps_external =
bblanchon/ArduinoJson@^6.18.0
[env:debug]
build_type = debug
${common.build_flags}
-D DEBUG
-D ENABLE_DEBUG_PRINT
-D APP_VERSION_POST='"debug"'
${common.lib_deps_builtin}
${common.lib_deps_external}
And the following sdkconfig
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
CONFIG_SDK_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_APP_COMPILE_TIME_DATE=y
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
CONFIG_BOOTLOADER_LOG_LEVEL_INFO=y
CONFIG_BOOTLOADER_LOG_LEVEL=3
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
CONFIG_BOOTLOADER_WDT_ENABLE=y
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
CONFIG_SECURE_SIGNED_ON_BOOT=y
CONFIG_SECURE_SIGNED_ON_UPDATE=y
CONFIG_SECURE_SIGNED_APPS=y
CONFIG_SECURE_BOOT_ENABLED=y
CONFIG_SECURE_BOOTLOADER_ONE_TIME_FLASH=y
CONFIG_SECURE_BOOT_BUILD_SIGNED_BINARIES=y
CONFIG_SECURE_BOOT_SIGNING_KEY="secure_boot_signing_key.pem"
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
CONFIG_ESPTOOLPY_FLASHFREQ="80m"
CONFIG_ESPTOOLPY_FLASHSIZE_2MB=y
CONFIG_ESPTOOLPY_FLASHSIZE="2MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD_115200B=y
CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions_4MB.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_4MB.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
CONFIG_ENABLE_ARDUINO_DEPENDS=y
CONFIG_ARDUINO_RUN_CORE1=y
CONFIG_ARDUINO_RUNNING_CORE=1
CONFIG_ARDUINO_EVENT_RUN_CORE1=y
CONFIG_ARDUINO_EVENT_RUNNING_CORE=1
CONFIG_ARDUINO_UDP_RUN_CORE1=y
CONFIG_ARDUINO_UDP_RUNNING_CORE=1
CONFIG_ARDUHAL_LOG_DEFAULT_LEVEL_ERROR=y
CONFIG_ARDUHAL_LOG_DEFAULT_LEVEL=1
CONFIG_ARDUHAL_PARTITION_SCHEME_DEFAULT=y
CONFIG_ARDUHAL_PARTITION_SCHEME="default"
CONFIG_ARDUINO_SELECTIVE_COMPILATION=y
CONFIG_ARDUINO_SELECTIVE_ArduinoOTA=y
CONFIG_ARDUINO_SELECTIVE_BLE=y
CONFIG_ARDUINO_SELECTIVE_EEPROM=y
CONFIG_ARDUINO_SELECTIVE_ESP32=y
CONFIG_ARDUINO_SELECTIVE_ESPmDNS=y
CONFIG_ARDUINO_SELECTIVE_HTTPClient=y
CONFIG_ARDUINO_SELECTIVE_Preferences=y
CONFIG_ARDUINO_SELECTIVE_SimpleBLE=y
CONFIG_ARDUINO_SELECTIVE_SPI=y
CONFIG_ARDUINO_SELECTIVE_Ticker=y
CONFIG_ARDUINO_SELECTIVE_Update=y
CONFIG_ARDUINO_SELECTIVE_WiFi=y
CONFIG_ARDUINO_SELECTIVE_WiFiClientSecure=y
CONFIG_ARDUINO_SELECTIVE_Wire=y
CONFIG_ARDUINO_SELECTIVE_HTTPUpdate=y
CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG=y
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_BT_ENABLED=y
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=y
CONFIG_BTDM_CTRL_BLE_MAX_CONN=3
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE_0=y
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_CTRL_HCI_MODE_VHCI=y
CONFIG_BTDM_MODEM_SLEEP=y
CONFIG_BTDM_MODEM_SLEEP_MODE_ORIG=y
CONFIG_BTDM_LPCLK_SEL_MAIN_XTAL=y
CONFIG_BTDM_BLE_DEFAULT_SCA_250PPM=y
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BTDM_BLE_SCAN_DUPL=y
CONFIG_BTDM_SCAN_DUPL_TYPE_DEVICE=y
CONFIG_BTDM_SCAN_DUPL_TYPE=0
CONFIG_BTDM_SCAN_DUPL_CACHE_SIZE=200
CONFIG_BTDM_CTRL_FULL_SCAN_SUPPORTED=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_SUPP=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_NUM=100
CONFIG_BTDM_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
CONFIG_BT_BLUEDROID_ENABLED=y
CONFIG_BT_BTC_TASK_STACK_SIZE=3072
CONFIG_BT_BLUEDROID_PINNED_TO_CORE_0=y
CONFIG_BT_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BT_BTU_TASK_STACK_SIZE=4096
CONFIG_BT_BLE_ENABLED=y
CONFIG_BT_GATTS_ENABLE=y
CONFIG_BT_GATTS_SEND_SERVICE_CHANGE_AUTO=y
CONFIG_BT_GATTS_SEND_SERVICE_CHANGE_MODE=0
CONFIG_BT_GATTC_ENABLE=y
CONFIG_BT_BLE_SMP_ENABLE=y
CONFIG_BT_STACK_NO_LOG=y
CONFIG_BT_ACL_CONNECTIONS=4
CONFIG_BT_SMP_ENABLE=y
CONFIG_BT_BLE_ESTAB_LINK_CONN_TOUT=30
CONFIG_BT_RESERVE_DRAM=0xdb5c
CONFIG_ADC_DISABLE_DAC=y
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
CONFIG_EFUSE_MAX_BLK_LEN=192
CONFIG_ESP32_REV_MIN_0=y
CONFIG_ESP32_REV_MIN=0
CONFIG_ESP32_DPORT_WORKAROUND=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=0
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
CONFIG_ESP32_BROWNOUT_DET_LVL=0
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_RTC_XTAL_CAL_RETRY=1
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
CONFIG_ESP32_XTAL_FREQ=40
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_ESP_MAIN_TASK_STACK_SIZE=3584
CONFIG_ESP_IPC_TASK_STACK_SIZE=1024
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
CONFIG_ESP_INT_WDT=y
CONFIG_ESP_INT_WDT_TIMEOUT_MS=300
CONFIG_ESP_INT_WDT_CHECK_CPU1=y
CONFIG_ESP_TASK_WDT=y
CONFIG_ESP_TASK_WDT_TIMEOUT_S=5
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_ETH_USE_ESP32_EMAC=y
CONFIG_ETH_PHY_INTERFACE_RMII=y
CONFIG_ETH_RMII_CLK_INPUT=y
CONFIG_ETH_RMII_CLK_IN_GPIO=0
CONFIG_ETH_DMA_BUFFER_SIZE=512
CONFIG_ETH_DMA_RX_BUFFER_NUM=10
CONFIG_ETH_DMA_TX_BUFFER_NUM=10
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE=y
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=32
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_FATFS_CODEPAGE_437=y
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
CONFIG_FMB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_FMB_MASTER_DELAY_MS_CONVERT=200
CONFIG_FMB_QUEUE_LENGTH=20
CONFIG_FMB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_FMB_SERIAL_BUF_SIZE=256
CONFIG_FMB_SERIAL_TASK_PRIO=10
CONFIG_FMB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_FMB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_FMB_CONTROLLER_STACK_SIZE=4096
CONFIG_FMB_EVENT_QUEUE_TIMEOUT=20
CONFIG_FMB_TIMER_PORT_ENABLED=y
CONFIG_FMB_TIMER_GROUP=0
CONFIG_FMB_TIMER_INDEX=0
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER=y
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
CONFIG_HEAP_POISONING_DISABLED=y
CONFIG_HEAP_TRACING_OFF=y
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=y
CONFIG_LWIP_IP_FRAG=y
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=6
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
CONFIG_LWIP_MAX_RAW_PCBS=16
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_HAVE_TIME=y
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
CONFIG_MBEDTLS_PSK_MODES=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_AES_C=y
CONFIG_MBEDTLS_RC4_DISABLED=y
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
CONFIG_MDNS_MAX_SERVICES=10
CONFIG_MQTT_PROTOCOL_311=y
CONFIG_MQTT_TRANSPORT_SSL=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE=y
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
CONFIG_OPENSSL_ASSERT_EXIT=y
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY=y
CONFIG_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
CONFIG_SPIFFS_MAX_PARTITIONS=3
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
CONFIG_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_TCPIP_LWIP=y
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30
CONFIG_WPA_MBEDTLS_CRYPTO=y
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=y
CONFIG_LOG_BOOTLOADER_LEVEL=3
CONFIG_FLASHMODE_DIO=y
CONFIG_MONITOR_BAUD_115200B=y
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
CONFIG_STACK_CHECK_NONE=y
CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=3
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=y
CONFIG_BLE_SCAN_DUPLICATE=y
CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y
CONFIG_SCAN_DUPLICATE_TYPE=0
CONFIG_DUPLICATE_SCAN_CACHE_SIZE=200
CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100
CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
CONFIG_BLUEDROID_ENABLED=y
CONFIG_BTC_TASK_STACK_SIZE=3072
CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
CONFIG_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BTU_TASK_STACK_SIZE=4096
CONFIG_GATTS_ENABLE=y
CONFIG_GATTS_SEND_SERVICE_CHANGE_AUTO=y
CONFIG_GATTS_SEND_SERVICE_CHANGE_MODE=0
CONFIG_GATTC_ENABLE=y
CONFIG_BLE_SMP_ENABLE=y
CONFIG_SMP_ENABLE=y
CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30
CONFIG_ADC2_DISABLE_DAC=y
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_CONSOLE_UART_DEFAULT=y
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=300
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_TIMEOUT_S=5
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
CONFIG_SW_COEXIST_ENABLE=y
CONFIG_MB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_MB_MASTER_DELAY_MS_CONVERT=200
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
CONFIG_MB_TIMER_PORT_ENABLED=y
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
CONFIG_SUPPORT_STATIC_ALLOCATION=y
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_TCP_OVERSIZE_MSS=y
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
CONFIG_IP_LOST_TIMER_INTERVAL=120
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# End of deprecated options
I got the following issue when I try to compile my application:
PLATFORM: Espressif 32 (1.12.4) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 0.0.0+sha.3616c2e
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 3.80200.200512 (8.2.0)
ValueError: path is on mount 'D:', start on mount 'C:':
File "C:\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 180:
File "C:\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Script\SConscript.py", line 597:
File "C:\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Script\SConscript.py", line 285:
File "C:\.platformio\platforms\espressif32\builder\main.py", line 223:
File "C:\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Util.py", line 748:
File "C:\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 61:
env.ProcessProgramDeps()
File "C:\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 128:
File "C:\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 343:
SConscript(env.GetFrameworkScript(f), exports="env")
File "C:\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Script\SConscript.py", line 660:
return method(*args, **kw)
File "C:\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 901:
build_components(env, framework_components_map, env.subst("$PROJECT_DIR"))
File "C:\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 723:
components_map[k]["lib"] = build_library(
File "C:\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 273:
lib_objects = compile_source_files(
File "C:\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 558:
target=join(obj_path, relpath(src_path, local_path) + ".o"),
File "C:\.platformio\python3\lib\ntpath.py", line 703:
raise ValueError("path is on mount %r, start on mount %r" % (
