I have a maturing project for esp32 that was born under platformio. The powers that be want the project to have signed firmware… you know where this is going.
Espressif documentation points towards secure boot v2.
Platformio doesn’t support it directly. When I run menuconfig and enable CONFIGURE_SECURE_BOOT_BUILD_SIGNED_BINARIES my build fails:
Compiling .pio/build/myenv/bootloader_support/src/secure_boot_v1/secure_boot_signatures_app.o
*** [.pio/build/myenv/.pio/build/myenv/signature_verification_key.bin.o] Source `.pio/build/myenv/signature_verification_key.bin.S' not found, needed by target `.pio/build/myenv/.pio/build/myenv/signature_verification_key.bin.o'.
Two problems there – one is the secure_boot_v1 which I’m told is no good, want v2 and the other problem is the baffed path construction (.pio/build/env/.pio/build/env/...)
At some point this becomes tedious and I think I’ll follow the instructions on Espressif’s website. They counsel using idf.py. So I do all that dance only to have the build fail in some other way (after building the esp-idf components it fails to find my code – much hacking on CMakeLists.txt later, I fix that but I’m still having include path problems).
So finally to my question… is there some document that describes how one extricates a project from platformio? Or describes how the wrapper tech works?
Really bummed out because there’s a lot to like about platformio.
