I am trying to use PlatformIO with the portable version of Visual Studio Code. I enabled portable mode in VSCode and want to install PlatformIO for portable use.
I cannot install the PlatformIO extension on the target PC directly because I have restricted internet access via a proxy, so the PlatformIO Core installation fails:
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Authentication Required',))': /simple/platformio/
Is it possible to install PlatformIO IDE on a different machine with full internet access on my portable VSCode version? Do I have to copy the %HOMEPATH%\.platformio folder? Does it matter that the user names differ on the two machines?
Or could I someone set the proxy settings? (I would prefer to manually copy files and not to do that, if possible and necessary).
Thank you
