Hey, I’m trying to flash this code to the microcontroller:
#include "controllers/stm32f407vg/stm32f4xx.h"
#include <utils/BitMacros.hpp>
void InitGPIO()
SystemInit();
constexpr int PD12 = 12;
ENABLE(GPIOD->MODER, 2 * PD12); // 0b01 -> General Purpose ouput
DISABLE(GPIOD->MODER, (2 * PD12) + 1);// set PD12 to Output
// PA0 - External Input
constexpr int PA0 = 0;
DISABLE(GPIOA->MODER, 2 * PA0); // set PA0 to be an input
DISABLE(GPIOA->MODER, (2 * PA0) + 1);// PA0 input
// PB3 - Input
constexpr int PB3 = 3;
DISABLE(GPIOB->MODER, 2 * PB3); // set PB3 to be an input
DISABLE(GPIOB->MODER, (2 * PB3) + 1);// PB3 input
void InitExtInt0()
__disable_irq(); // cmsis_gcc.h - Disable interrupts globally
// Trigger EXTI0 with PA0 (EXTI[X] -> P[Y][X])
constexpr uint32_t Port = 0; // PA
constexpr uint32_t EXTIX = 0; // EXTI0
constexpr uint32_t Trigger = 0b01; // Rising Edge
if (EXTIX > 22) return;
P[X] will trigger the interrupt
let Port be A and EXTIX be 1,
this will lead to PA1 to trigger the interupt EXTI1
SYSCFG->EXTICR[EXTIX / 4] |= (Port << (EXTIX % 4));
// Trigger event and interrupt
ENABLE(EXTI->IMR, EXTIX); // InterruptMaskRegister
ENABLE(EXTI->EMR, EXTIX); // EventMaskRegister
if (IS_SET(Trigger, 0))
ENABLE(EXTI->RTSR, EXTIX);
else
DISABLE(EXTI->RTSR, EXTIX);
if (IS_SET(Trigger, 1))
ENABLE(EXTI->FTSR, EXTIX);
else
DISABLE(EXTI->FTSR, EXTIX);
NVIC_EnableIRQ(EXTI0_IRQn);
__enable_irq();
void delay_ms(unsigned int ms)
int resetValue = 6 * SystemCoreClock / (SystemCoreClock / 1000);
while (ms-- > 0)
int x = resetValue;
while (x-- > 0)
__asm("nop");
void ToggleLED()
TOGGLE(GPIOD->ODR, PD12);
extern "C" void EXTI0_IRQHandler()
ToggleLED();
ENABLE(EXTI->PR, EXTI0_IRQn);
int main()
InitGPIO(); // configure GPIO
InitExtInt0(); // configure external interrupt
while(true){};
[platformio]
default_envs = stm32f407vg
[common]
src_filter =
-<.git/>
-<.svn/>
-<example/>
-<examples/>
-<test/>
-<tests/>
-<target/>
-<controllers/>
-<shared/>
# C++17 is needed for inline static definitions.
# if no inline static is used, these flags can be omitted
-std=c++1z
-std=gnu++1z
[env]
build_type = debug
[env:stm32f407vg]
platform = ststm32
board = disco_f407vg
src_filter =
${common.src_filter}
${common.build_flags}
-D STM32F407VG
-D DEBUG
upload_protocol = stlink
upload_port = /dev/cu.usbmodem14103
debug_tool = stlink
I’m getting weird assertion errors from openocd:
> Executing task: platformio run --target upload --environment stm32f407vg <
Processing stm32f407vg (platform: ststm32; board: disco_f407vg)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/disco_f407vg.html
PLATFORM: ST STM32 6.0.0 > ST STM32F4DISCOVERY
HARDWARE: STM32F407VGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, jlink)
- tool-dfuutil 1.9.190708
- tool-openocd 2.1000.190707 (10.0)
- tool-stm32duino 1.0.1
Found 0 compatible libraries
Building in debug mode
arm-none-eabi-g++ -o .pio/build/stm32f407vg/src/main.o -c -fno-rtti -fno-exceptions -std=c++1z -std=gnu++1z -ffunction-sections -fdata-sections -Wall -mthumb -nostdlib -mcpu=cortex-m4 -Og -g2 -ggdb2 -DF_CPU=168000000L -DDISCO_F407VG -DPLATFORMIO=40200 -DSTM32F4 -DSTM32F407xx -DSTM32F40_41xxx -DARDUINO_STM32DiscoveryF407 -DBOARD_discovery_f4 -DSTM32F407VG -DDEBUG -D__PLATFORMIO_BUILD_DEBUG__ -Iinclude -Isrc src/main.cpp
arm-none-eabi-g++ -o .pio/build/stm32f407vg/firmware.elf -T stm32f405x6.ld -Wl,--gc-sections,--relax -mthumb -nostartfiles -nostdlib -mcpu=cortex-m4 -Og -g2 -ggdb2 .pio/build/stm32f407vg/src/main.o -L/Users/john/.platformio/platforms/ststm32/ldscripts -L.pio/build/stm32f407vg -Wl,--start-group -lc -lgcc -lm -lstdc++ -lnosys -Wl,--end-group
/Users/john/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: warning: cannot find entry symbol Reset_Handler; defaulting to 0000000008000000
MethodWrapper(["checkprogsize"], [".pio/build/stm32f407vg/firmware.elf"])
RAM: [ ] 0.0% (used 0 bytes from 131072 bytes)
Flash: [ ] 0.0% (used 0 bytes from 1048576 bytes)
.pio/build/stm32f407vg/firmware.elf :
section size addr
.isr_vector 0 134217728
.text 0 134217728
.data 0 536870912
.bss 0 536870912
._user_heap_stack 1024 536870912
Total 1024
<lambda>(["upload"], [".pio/build/stm32f407vg/firmware.elf"])
AVAILABLE: blackmagic, jlink, mbed, stlink
openocd -d2 -s /Users/john/.platformio/packages/tool-openocd/scripts -f board/stm32f4discovery.cfg -c "program {.pio/build/stm32f407vg/firmware.elf} verify reset; shutdown;"
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-15:21)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
Info : clock speed 2000 kHz
Info : STLINK V2J31M21 (API v2) VID:PID 0483:374B
Info : Target voltage: 2.887632
Error: jtag status contains invalid mode value - communication failure
Polling target stm32f4x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Error: mem2array: Read @ 0xe0042004, w=4, cnt=1, failed
Error executing event examine-end on target stm32f4x.cpu:
/Users/john/.platformio/packages/tool-openocd/scripts/mem_helper.tcl:6: Error:
in procedure 'program'
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 214
in procedure 'mmw' called at file "/Users/john/.platformio/packages/tool-openocd/scripts/target/stm32f4x.cfg", line 79
in procedure 'mrw' called at file "/Users/john/.platformio/packages/tool-openocd/scripts/mem_helper.tcl", line 36
at file "/Users/john/.platformio/packages/tool-openocd/scripts/mem_helper.tcl", line 6
xPSR: 0x01000000 pc: 0x080001c0 msp: 0x20020000
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
** Programming Started **
Assertion failed: (image->num_sections > 0), function image_elf_read_headers, file /Users/ilg/Work/openocd-0.10.0-13/openocd.git/src/target/image.c, line 432.
*** [upload] Error -6
=========================================================================================== [FAILED] Took 1.08 seconds ===========================================================================================
Environment Status Duration
atmega328p IGNORED
lpc1768 IGNORED
stm32f407vg FAILED 00:00:01.083
===================================================================================== 1 failed, 0 succeeded in 00:00:01.083 =====================================================================================
General uploads worked fine a while ago.
When trying to debug, I get this:
section size addr
.text 0 134217728
.data 0 536870912
.bss 0 536870912
Total 1024
========================= [SUCCESS] Took 0.55 seconds =========================
atmega328p IGNORED
lpc1768 IGNORED
stm32f407vg SUCCESS 00:00:00.549
========================= 1 succeeded in 00:00:00.549 =========================
Reading symbols from /Users/john/Documents/PlatformIO/Projects/Testing_MCB1768/.pio/build/stm32f407vg/firmware.elf...
(no debugging symbols found)...done.
Info : tcl server disabled
Info : telnet server disabled
Info : Target voltage: 2.886219
Info : device id = 0x10076413
Info : flash size = 1024 kbytes
Info : flash size = 512 bytes
0x080001c0 in ?? ()
Start address 0x8000000, load size 0
Transfer rate: 0 bits in <1 sec.
Function "main" not defined.
Make breakpoint pending on future shared library load? (y or [n]) [answered N; input not from terminal]
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
pio_reset_run_target
Cannot execute this command while the target is running.
Use the "interrupt" command to stop the target
and then try again.
and then try again.
and then try again.
