I edited the post above, due to new user limit
I notice that when running as root, the gpio4 gets created during sudo pio run -t upload and disappears when command has finished.
@glynhudson is it true? You said me that GPIO 18 should be used.
Opsss. I’ve just changed your level manually. The system is very “smart” ![]()
No, we never fixed this. We came to the conclusion that due to Raspbian root user is needed to access GPIO. I have been living with running pio as sudo to upload. Not ideal, but IMO is not the end of the world since the emonPi is a closed system on a RaspberryPi.
The emonPi uses GPIO 4 (pin 7) as the reset.
Hey
Would be glad for the feedback. I remember that you were interested in Library Managment.
Hi
I 'm trying to load firmware to an ATtiny85 with raspberry pi, it is that possible?
Thanks
It’s possible. PlatformIO works on Raspberry Pi too.
Thanks @ivankravets, the platformio.ini, would look like ?
[env:attiny85]
board = attiny85
board_f_cpu = 1000000L
upload_port =/dev/ttyAMA0
Yes, that is the core idea of PlatformIO to work with the same project settings everywhere with the same manner.
Default use programmer “usbtiny” and I want to use “linuxspi” or GPIO
Is Possible?
Please read docs Redirecting...
You need upload_protocol.
I am try with
“upload_protocol = -P /dev/spidev0.0 -c linuxspi -b 10000”
but next error:
avrdude: Can't find programmer id "-P
Do you have any example of upload_protocol?
Thanks
What are you doing? Please read docs and examples below:
upload_protocol = linuxspi
upload_speed = 10000
and etc… See upload_flags…
See program examples Atmel AVR — PlatformIO v6.1 documentation
[env:attiny85]
board = attiny85
upload_flags = -P$UPLOAD_PORT
upload_port = /dev/spidev0.0
and use pio run -t program.
I am try with
upload_flags = -P /dev/spidev0.0
I am doing programming attiny85 with Raspberry Pi, similar to
http://www.instructables.com/id/Programming-the-ATtiny85-from-Raspberry-Pi/ in the step 3
Try this
[env:attiny85]
board = attiny85
board_mcu = t85
extra_script = extra_script.py
However, that is not enough. You need to make software reset. See
sudo gpio -g mode 22 out
sudo gpio -g write 22 0
We have this software reset on other pins for raspduino and emonpi. Nevertheless, you can write custom extra_script and 2 hooks. Do you familiar with Python?
See my answer here
Place it on the same level as platformio.ini
Import("env")
def _rpi_sysgpio(path, value):
with open(path, "w") as f:
f.write(str(value))
def before_upload(source, target, env):
_rpi_sysgpio("/sys/class/gpio/export", 22)
_rpi_sysgpio("/sys/class/gpio/gpio22/direction", "out")
_rpi_sysgpio("/sys/class/gpio/gpio22value", 0)
def after_upload(source, target, env):
_rpi_sysgpio("/sys/class/gpio/gpio22value", 1)
env.AddPreAction("program", before_upload)
env.AddPostAction("program", after_upload)
P.S: Need to run with sudo. RPi requires it.
I have the next error:
scons: *** Import of non-existent variable ''env''
Please switch to PlatformIO 3.0 Redirecting...
Done
I have the same error with programmer:
avrdude: Can't find programmer id "linuxspi"
it may be that the version of avrdude of platformio does not support this type of controller
I can use the default avrdude the raspberry ?
You need special avrdude. See instruction that you gave me:
git clone GitHub - kcuzner/avrdude: avrdude with a Linux SPI programmer type
cd avrdude/avrdude
./bootstrap && ./configure && sudo make install
Then, need to force PlatformIO use this avrdude. Please edit extra_script.py and before_upload function
env.Replace(UPLOADER="/path/to/hacked/avrdude")
