I am trying with
env.Replace(UPLOADER="/usr/bin/avrdude")
that is the version avrdude default for raspberry pi and linuxspi programmer if it is available, but platformio does not detect it
I am trying with
I’ve just checked and it works for me
pio run -t program -v
[Fri Aug 26 16:22:00 2016] Processing uno (extra_script: extra_script.py, platform: atmelavr, board: uno, framework: arduino)
Framework incompatible library /Users/ikravets/.platformio/lib/MODSERIAL_ID218
Framework incompatible library /Users/ikravets/.platformio/lib/Servo
Framework incompatible library /Users/ikravets/.platformio/lib/TextLCD
More details about "Library Compatibility Mode": http://docs.platformio.org/en/latest/librarymanager/ldf.html#ldf-compat-mode
Collected 37 compatible libraries
Looking for dependencies...
Project does not have dependencies
Current build targets ['program']
before_upload(["program"], [".pioenvs/uno/firmware.hex"])
before_upload
BeforeUpload(["program"], [".pioenvs/uno/firmware.hex"])
/path/to/hacked/avrdude -v -p atmega328p -C "/Users/ikravets/.platformio/packages/tool-avrdude/avrdude.conf" -c arduino -U flash:w:.pioenvs/uno/firmware.hex:i
sh: /path/to/hacked/avrdude: No such file or directory
scons: *** [program] Error 127
extra_script.py aboveprogram targetenv.AddPreAction("program", before_upload).--verbose.Working, but I have the next error
scons: *** [program] /sys/class/gpio/gpio22value: Permission denied
I am run with sudo
sudo pio run -t program -v
Could you try to restart RPi?
Yes, if not restart i have the next error
scons: *** [program] Device or resource busy
Please try to disable “after” uploading
# env.AddPostAction("program", after_upload)
Same error
Could you flash this board without PIO?
Working!!
My platformio.ini is:
[env:attiny85]
board = attiny85
board_f_cpu = 800000
upload_flags = -C /etc/avrdude.conf -P$UPLOAD_PORT -b 10000
upload_protocol = linuxspi
upload_port = /dev/spidev0.0
extra_script = extra_script.py
Thanks!
Aaaaa /etc/avrdude.conf
Yep, the config also should be used a correct.
My congrats! That was really interesting for me to resolve this task with PlatformIO. Now I understand how is PlatformIO powerfull
