Dear @pio3-dev ,
We are glad to announce the first public development version of PlatformIO 3.0 and invite you to test it with your projects.
New features
Installation
Release Notes
PlatformIO Plus
Decentralized Development Platforms
Library Manager 3.0
Project dependencies per build environment using lib_deps option issue #413
Semantic Versioning for library commands and dependencies issue #410
Multiple library storages: Project’s Local, PlatformIO’s Global or Custom issue #475
Install library by name issue #414
Depend on a library using VCS URL (GitHub, Git, ARM mbed code registry, Hg, SVN) issue #498
Strict search for library dependencies issue #588
Allowed library.json to specify sources other than PlatformIO’s Repository issue #461
New Intelligent Library Build System
Library Dependency Finder that interprets C/C++ Preprocessor conditional macros with deep search behavior
Check library compatibility with project environment before building issue #415
Control Library Dependency Finder for compatibility using lib_compat_mode option
Custom library storages/directories with lib_extra_dirs option issue #537
Handle extra build flags, source filters and build script from library.json issue #289
Allowed to disable library archiving (*.ar) issue #719
Show detailed build information about dependent libraries issue #617
Support for the 3rd party manifests (Arduino IDE “library.properties”
and ARM mbed “module.json”)
Print human-readable information when processing environments without -v, --verbose option
issue #721
Added license field to library.json issue #522
Warn about unknown options in project configuration file platformio.ini issue #740
Stopped supporting Python 2.6
Screenshots
Project Dependencies Graph
Global libraries list
Update global libraries
Regards,
The PlatformIO Team
andig
August 9, 2016, 6:06am
4
Good morning. Either I’m missing something or… the development version is still 2.11. So how to install?
How did you install development version?
andig
August 9, 2016, 11:08am
6
As the docs day:
# uninstall existing version
pip uninstall platformio
# install the latest development version of PlatformIO
pip install -U https://github.com/platformio/platformio/archive/develop.zip
Do you use PlatformIO IDE Terminal?
Hi!
I’ve tested 3.0 on macOS with platformio-ide and command line.
The command line installation works only as root (sudo).
To switch back to the ide-version i had to uncheck the “Use Development version…” and click it again.
Tested a lot of projects (atmelavr and espressif) and all works perfect.
Switching different version of global libs works as well.
For the sake of completeness i should mention a cosmetic flaw:
The first line of compilation is always:
"Warning! Ignore unknown envs_dir option from [platformio] section"
Which isn’t true because envs_dir option is not ignored.
Robert
Thanks a lot for the report!
Thanks, I’ve just fixed it
committed 08:44PM - 09 Aug 16 UTC
I forgot that “pio run -t clean” also did not work in my case…
Robert
eg. the blink example:
pio --version
PlatformIO, version 3.0.0a4
pio run -t clean -e uno
[Wed Aug 10 19:42:24 2016] Processing uno (platform: atmelavr, board: uno, framework: arduino)
Collected 35 compatible libraries
Looking for dependencies…
Project does not have dependencies
================== [SUCCESS] Took 0.61 seconds ==================
ls /tmp/pio/blink/uno/src/
Blink.o
FrameworkArduino firmware.hex libFrameworkArduinoVariant.a
firmware.elf libFrameworkArduino.a src
guess these files should not be there…
Robert
Could try the same with -v option?
pio run -t clean -e uno -v
the same…
[Wed Aug 10 20:16:01 2016] Processing uno (platform: atmelavr, board: uno, framework: arduino)
=================== [SUCCESS] Took 0.65 seconds ===================
I can’t reproduce this issue Could you try to remove .pioenvs directory manually and try again?
I figured out that this only happens with envs_dir set.
e.g.:
[platformio]
envs_dir = /tmp/pio/blink
can you reproduce this?
Robert
andig
August 12, 2016, 1:23pm
18
No, I had actually done this through the normal terminal. Working now when run through IDE- thanks!
andig
August 12, 2016, 1:26pm
19
One thing I notice is that the builds have become slower. Previously, I was using the packaged libraries. With 3.0 I can refer to git repos instead:
; lib_install = 1,19,31,54,64,306,346
OneWire
Adafruit-DHT
Adafruit-Unified-Sensor
DallasTemperature
Json
me-no-dev/ESPAsyncTCP
me-no-dev/ESPAsyncWebServer
marvinroger/async-mqtt-client
When I do this I notice that the (re)compile times almost double for my project from 2.7 to 4.7 seconds.
Maybe the builder recompiles the git libraries instead of relying on compiled objects?Other ideas for possible causes?
I can successfully install pio 3.0.0a6, but when I try to build, i get the following errors:
MacPro:flxs1 tenkai$ pio run -v
[Mon Aug 22 13:37:51 2016] Processing teensy31 (platform: teensy, board_f_cpu: 96000000, build_flags: , board: teensy31, framework: arduino)
ValueError: Expecting property name: line 11 column 1 (char 291):
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/main.py”, line 125:
env.SConscript(“$BUILD_SCRIPT”)
File “/Users/tenkai/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 551:
File “/Users/tenkai/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 260:
exec file in call_stack[-1].globals
File “/Users/tenkai/.platformio/platforms/teensy/builder/main.py”, line 199:
File “/Users/tenkai/.platformio/packages/tool-scons/script/…/engine/SCons/Environment.py”, line 224:
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/platformio.py”, line 61:
deplibs = env.BuildDependentLibraries(“$PROJECTSRC_DIR”)
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/piolib.py”, line 514:
lib_builders = env.GetLibBuilders()
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/piolib.py”, line 489:
lb = LibBuilderFactory.new(env, join(libs_dir, item))
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/piolib.py”, line 50:
obj = getattr(sys.modules[name ], clsname)(env, path)
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/piolib.py”, line 85:
self._manifest = manifest if manifest else self.load_manifest()
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/builder/tools/piolib.py”, line 393:
manifest = util.load_json(join(self.path, “library.json”))
File “/Users/tenkai/.atom/packages/platformio-ide/penv/lib/python2.7/site-packages/platformio/util.py”, line 132:
return json.load(f)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/init .py”, line 290:
**kw)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/init .py”, line 338:
return _default_decoder.decode(s)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py”, line 366:
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py”, line 382:
obj, end = self.scan_once(s, idx)
============================================================================================== [ERROR] Took 0.49 seconds ==============================================================================================
I have opened a bug in github for this one.
