@glynhudson I remember that you had the same problem. Have we resolved it?
I edited the post above, due to new user limit
I notice that when running as root, the gpio4 gets created during sudo pio run -t upload
and disappears when command has finished.
Opsss. Iâve just changed your level manually. The system is very âsmartâ
No, we never fixed this. We came to the conclusion that due to Raspbian root user is needed to access GPIO. I have been living with running pio as sudo to upload. Not ideal, but IMO is not the end of the world since the emonPi is a closed system on a RaspberryPi.
The emonPi uses GPIO 4 (pin 7) as the reset.
Hey Would be glad for the feedback. I remember that you were interested in Library Managment.
Hi
I 'm trying to load firmware to an ATtiny85 with raspberry pi, it is that possible?
Thanks
Itâs possible. PlatformIO works on Raspberry Pi too.
Thanks @ivankravets, the platformio.ini, would look like ?
[env:attiny85]
platform = atmelavr
board = attiny85
board_f_cpu = 1000000L
upload_port =/dev/ttyAMA0
Yes, that is the core idea of PlatformIO to work with the same project settings everywhere with the same manner.
Default use programmer âusbtinyâ and I want to use âlinuxspiâ or GPIO
Is Possible?
I am try with
âupload_protocol = -P /dev/spidev0.0 -c linuxspi -b 10000â
but next error:
avrdude: Can't find programmer id "-P
Do you have any example of upload_protocol?
Thanks
What are you doing? Please read docs and examples below:
upload_protocol = linuxspi
upload_speed = 10000
and etc⌠See upload_flags
âŚ
See program examples Atmel AVR â PlatformIO v6.1 documentation
[env:attiny85]
platform = atmelavr
board = attiny85
upload_flags = -P$UPLOAD_PORT
upload_port = /dev/spidev0.0
and use pio run -t program
I am try with
upload_flags = -P /dev/spidev0.0
I am doing programming attiny85 with Raspberry Pi, similar to
http://www.instructables.com/id/Programming-the-ATtiny85-from-Raspberry-Pi/ in the step 3
Try this
[env:attiny85]
platform = atmelavr
board = attiny85
board_mcu = t85
extra_script = extra_script.py
However, that is not enough. You need to make software reset. See
sudo gpio -g mode 22 out
sudo gpio -g write 22 0
We have this software reset on other pins for raspduino
and emonpi
. Nevertheless, you can write custom extra_script and 2 hooks. Do you familiar with Python?
See my answer here
extra_script.py
Place it on the same level as platformio.ini
Import("env")
def _rpi_sysgpio(path, value):
with open(path, "w") as f:
f.write(str(value))
def before_upload(source, target, env):
_rpi_sysgpio("/sys/class/gpio/export", 22)
_rpi_sysgpio("/sys/class/gpio/gpio22/direction", "out")
_rpi_sysgpio("/sys/class/gpio/gpio22value", 0)
def after_upload(source, target, env):
_rpi_sysgpio("/sys/class/gpio/gpio22value", 1)
env.AddPreAction("program", before_upload)
env.AddPostAction("program", after_upload)
P.S: Need to run with sudo
. RPi requires it.
I have the next error:
scons: *** Import of non-existent variable ''env''
Done
I have the same error with programmer:
avrdude: Can't find programmer id "linuxspi"
it may be that the version of avrdude of platformio does not support this type of controller
I can use the default avrdude the raspberry ?
