Upload without recompile
When I select Upload from Project tasks, the IDE always compiles and links first even if the Build command just has run.
How can I upload only without the compilation and linking?
Open a new pio terminal and use the following command:
pio run -t nobuild -t upload
You can also edit the toolbar and add this as an extra icon.
  • Click the VS Code Gear Icon
  • Choose “Settings”
  • Navigate to “Extensions / PlatformIO IDE”
  • Toolbar → choose "Edit in settings
Edit the toolbar like so:
   "platformio-ide.toolbar": [
            "text": "$(debug-step-out)",
            "tooltip": "PlatformIO: Upload without build",
            "commands": [
                    "id": "platformio-ide.runPIOCoreCommand",
                    "args": "pio run -t nobuild -t upload"
Fantastic! Finally working! Thank You!
How can I add the menu item at the bottom as a keyboard shortcut?
Sorry, I don’t know…
great solution, but can you explan how to “edit the toolbar” I did not get it !?
As written above:
  • Click the VS Code Gear Icon:
  • Choose “Settings”
Yes, you get an icon at the bottom left of VS Code window by editing the settings.json file.
The question is how do I map such an icon to a keyboard shortcut?
I don’t think you can bind this “Icon” to a keyboard shortcut.
One solution could be to create a new Task (Terminal / Configure Task / Create …)
Then enter the command to be executed:
    // See https://go.microsoft.com/fwlink/?LinkId=733558
    // for the documentation about the tasks.json format
    "version": "2.0.0",
    "tasks": [
            "label": "Buld without upload",
            "type": "shell",
            "command": "pio run -t nobuild -t upload"
Note: The PATH must include the location of the pio.exe.
This task can be bound to a keyboard shortcut by editing the keybindings.json.
But this is stuff for a VS Code forum, not PlatformIO.
