PlatformIO, version 4.0.0a3
MacOS 10.14.3
In my platformio.ini
file, I have the serial port for my device defined as upload_port = /dev/cu.usbserial-14413440
, which matches what I see in ls /dev/cu.*
output and matches what I see in pio device list
/dev/cu.usbserial-14413430
Hardware ID: USB VID:PID=1A86:7523 LOCATION=20-4.1.3.4.3
Description: USB2.0-Serial
However, when I try to upload my project (an ESP8266/Arduino project), PIO tries to upload via OTA. This is a new problem. Just 3 days ago, uploading by serial worked fine. I did not make changes to the platformio.ini
file in that time.
Iām not sure what the issue is, but is there a way to force PIO to perform serial upload? Iāve also tried with the tty
version of the port (/dev/tty.usbserial-14413430
), but it has the same issue.
What command are you using for uploading? Via the CLI or an IDE? What is the verbose output of that procedure?
Happens in both IDE (VSCode) and CLI, using command pio run --target upload
The non-verbose output is:
Looking for upload port...
Use manually specified: /dev/cu.usbserial-14413430
Uploading .pioenvs/nodemcu/firmware.bin
06:09:11 [DEBUG]: Options: {'timeout': 10, 'esp_ip': '/dev/cu.usbserial-14413430', 'host_port': 33677, 'image': '.pioenvs/nodemcu/firmware.bin', 'host_ip': '0.0.0.0', 'auth': '', 'esp_port': 8266, 'spiffs': False, 'debug': True, 'progress': True}
06:09:11 [INFO]: Starting on 0.0.0.0:33677
06:09:11 [INFO]: Upload size: 273568
Sending invitation to /dev/cu.usbserial-14413430 ....failed
06:09:50 [ERROR]: Host /dev/cu.usbserial-14413430 Not Found
I just tried to enable verbose, and now it correctly finds the serial port and uploads properly. I made no changes to the code or settings, the host computer was not even restarted, the hardware (NodeMCU) was not uplugged. Odd.
Can you show your full platformio.ini
[platformio]
env_default = nodemcu
[common_env_data]
FastLED
[env:d1_mini]
platform = espressif8266
board = d1_mini
framework = ${common_env_data.framework}
monitor_port = /dev/cu.usbserial-14413440
monitor_speed = ${common_env_data.monitor_speed}
lib_deps = ${common_env_data.lib_deps}
[env:nodemcu]
board = nodemcu
upload_port = /dev/cu.usbserial-14413430
monitor_port = /dev/cu.usbserial-14413430
This happens on Windows platforms too and is a serious issue.
The new 2.0.x releases appear to break the upload_port setting in platformio.ini: it looks like it now interprets the upload_port as an IP address instead of a COM port. This is very easy to reproduce: for example, using the auto-generated platformio.ini configuration and adding just the upload port specification:
[env:esp12e]
board = esp12e
upload_port=COM5
Attempts to upload to target now result in:
Uploading .pioenvs\esp12e\firmware.bin
12:08:00 [DEBUG]: Options: {'timeout': 10, 'esp_ip': 'COM5', 'host_port': 46511, 'image': '.pioenvs\\esp12e\\firmware.bin', 'host_ip': '0.0.0.0', 'auth': '', 'esp_port': 8266, 'spiffs': False, 'debug': True, 'progress': True}
12:08:00 [INFO]: Starting on 0.0.0.0:46511
12:08:00 [INFO]: Upload size: 262160
Sending invitation to COM5 ..........
12:09:41 [ERROR]: No response from the ESP
Any ideas? I didnāt see anything helpful in the release notes. How do I tell it to use a specific serial port for upload? (Note: if no upload port is specified, it auto-detects the first serial port, but thatās not the one I need to use).
I cannot reproduce this on my Windows PC.
platformio.ini
[env:nodemcuv2]
board = nodemcuv2
upload_port = COM7
Upload via pio run -t upload -v
<lambda>(["upload"], [".pioenvs\nodemcuv2\firmware.bin"])
MethodWrapper(["upload"], [".pioenvs\nodemcuv2\firmware.bin"])
Use manually specified: COM7
esptool -vv -cd nodemcu -cb 115200 -cp "COM7" -cf .pioenvs\nodemcuv2\firmware.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM7
espcomm_upload_file
writing flash
................................................................................ [ 31% ]
................................................................................ [ 62% ]
................................................................................ [ 93% ]
................. [ 100% ]
======================================================================================================= [SUCCESS] Took 35.39 seconds =======================================================================================================
Can you try via the terminal?
Same problem when run from the terminalā¦it is 100% reproducible. If I comment out the upload_port (and the target is the first serial port), it uploads over serial. However if I un-comment that line, it attempts an OTA upload.
([āuploadā], [".pioenvs\esp12e\firmware.bin"])
MethodWrapper([āuploadā], [".pioenvs\esp12e\firmware.bin"])
Use manually specified: COM5
āc:\users\david.platformio\penv\scripts\python.exeā āC:\Users\david.platformio\packages\tool-espotapy\espota.pyā --debug --progress -i COM5 -f .pioenvs\esp12e\firmware.bin
12:51:51 [DEBUG]: Options: {ātimeoutā: 10, āesp_ipā: āCOM5ā, āhost_portā: 41851, āimageā: ā.pioenvs\esp12e\firmware.binā, āhost_ipā: ā0.0.0.0ā, āauthā: āā, āesp_portā: 8266, āspiffsā: False, ādebugā: True, āprogressā: True}
12:51:51 [INFO]: Starting on 0.0.0.0:41851
12:51:51 [INFO]: Upload size: 509408
Time to compare versions then. Can you please upgrade the core to the latest dev version using pio upgrade --dev
in the terminal? Also whatās the platform-esp8266
version when you type in pio platforms show espressif8266
? Itās Version: 2.0.1
for me.
Itās 2.0.1 for me too. Note: Iāve tried falling back to 2.0.x and it has the same issue.
PS C:\Users\david\Documents\PlatformIO\Projects\Gateway2> pio platforms show espressif8266
espressif8266 ~ Espressif 8266
Espressif Systems is a privately held fabless semiconductor company. They provide wireless communications and Wi-Fi chips which are widely used in mobile devices and the Internet of Things applications.
Version: 2.0.1
Home: http://platformio.org/platforms/espressif8266
Repository: https://github.com/platformio/platform-espressif8266.git
Vendor: https://espressif.com/
License: Apache-2.0
Frameworks: arduino, esp8266-nonos-sdk, esp8266-rtos-sdk, simba
Packages
Package framework-esp8266-rtos-sdk
Type: framework
Requirements: >=1.5.0-beta
Installed: No (optional)
Package toolchain-xtensa
Type: toolchain
Requirements: ~1.40802.0
Installed: Yes
Version: 1.40802.0
Original version: 4.8.2
Description: xtensa-gcc
Package framework-simba
Type: framework
Requirements: >=7.0.0
Package tool-esptool
Type: uploader
Requirements: <2
Installed: Yes
Version: 1.413.0
Original version: 4.13
Description: esptool-ck
Package tool-mkspiffs
Type: uploader
Requirements: ~1.200.0
Installed: Yes
Version: 1.200.0
Original version: 2.0
Description: Tool to build and unpack SPIFFS images
Package tool-espotapy
Type: uploader
Requirements: ~1.1.0
Installed: Yes
Version: 1.1.3
Original version: None
Description: This script will push an OTA update to the ESP
Package framework-arduinoespressif8266
Type: framework
Requirements: ~2.20500.0
Installed: Yes
Version: 2.20500.190223
Original version: 2.5.0
Description: Arduino Wiring-based Framework (ESP8266 Core)
Package sdk-esp8266
Requirements: ~1.10502.0
Installed: Yes
Version: 1.10502.0
Original version: 1.5.2
Description: ESP8266 SDK
Package framework-esp8266-nonos-sdk
Type: framework
Requirements: >=2.1.0
Boards
ID MCU Frequency Flash RAM Name
nodemcuv2 ESP8266 80MHz 4MB 80KB NodeMCU 1.0 (ESP-12E Module)
wifinfo ESP8266 80MHz 1MB 80KB WifInfo
esp01_1m ESP8266 80MHz 1MB 80KB Espressif Generic ESP8266 ESP-01 1M
d1_mini ESP8266 80MHz 4MB 80KB WeMos D1 R2 and mini
espduino ESP8266 80MHz 4MB 80KB ESPDuino (ESP-13 Module)
esp12e ESP8266 80MHz 4MB 80KB Espressif ESP8266 ESP-12E
heltec_wifi_kit_8 ESP8266 80MHz 4MB 80KB Heltec Wifi kit 8
wifiduino ESP8266 80MHz 4MB 80KB WiFiduino
huzzah ESP8266 80MHz 4MB 80KB Adafruit HUZZAH ESP8266
phoenix_v1 ESP8266 80MHz 4MB 80KB Phoenix 1.0
phoenix_v2 ESP8266 80MHz 4MB 80KB Phoenix 2.0
d1 ESP8266 80MHz 4MB 80KB WEMOS D1 R1 (Retired)
esp01 ESP8266 80MHz 512KB 80KB Espressif Generic ESP8266 ESP-01 512k
esp07 ESP8266 80MHz 4MB 80KB Espressif Generic ESP8266 ESP-07
thing ESP8266 80MHz 512KB 80KB SparkFun ESP8266 Thing
esp_wroom_02 ESP8266 80MHz 2MB 80KB ESP-WROOM-02
sparkfunBlynk ESP8266 80MHz 4MB 80KB SparkFun Blynk Board
oak ESP8266 80MHz 4MB 80KB DigiStump Oak
wifi_slot ESP8266 80MHz 4MB 80KB WiFi Slot
nodemcu ESP8266 80MHz 4MB 80KB NodeMCU 0.9 (ESP-12 Module)
d1_mini_lite ESP8266 80MHz 1MB 80KB WeMos D1 mini Lite
espresso_lite_v1 ESP8266 80MHz 4MB 80KB ESPresso Lite 1.0
espresso_lite_v2 ESP8266 80MHz 4MB 80KB ESPresso Lite 2.0
d1_mini_pro ESP8266 80MHz 16MB 80KB WeMos D1 mini Pro
esp8285 ESP8266 80MHz 1MB 80KB Generic ESP8285 Module
espino ESP8266 80MHz 4MB 80KB ESPino
inventone ESP8266 80MHz 4MB 80KB Invent One
espinotee ESP8266 80MHz 4MB 80KB ThaiEasyElec ESPino
espectro ESP8266 80MHz 4MB 80KB ESPectro Core
thingdev ESP8266 80MHz 512KB 80KB SparkFun ESP8266 Thing Dev
modwifi ESP8266 80MHz 2MB 80KB Olimex MOD-WIFI-ESP8266(-DEV)
wio_link ESP8266 80MHz 4MB 80KB Wio Link
gen4iod ESP8266 80MHz 512KB 80KB 4D Systems gen4 IoD Range
xinabox_cw01 ESP8266 80MHz 4MB 80KB XinaBox CW01
esp210 ESP8266 80MHz 4MB 80KB SweetPea ESP-210
wio_node ESP8266 80MHz 4MB 80KB Wio Node
There is a suspicious commit Branch for espota if port resolved (#97) Ā· platformio/platform-espressif8266@54cd0fb Ā· GitHub which might have caused this. The previous logic only allowed IP address strings to be OTA upload ports. The new logic checks if it can resolve the name. Can you try to write upload_protocol = esptool
in the platformio.ini
You might also try to platform = espressif8266@1.8.0
where this commit wasnāt yet present.
Iāll try that. I should mention in case itās related that Iām getting a task error when I launch the upload:
Error: The PlatformIO task detection didnāt contribute a task for the following configuration:
ātypeā: āPlatformIOā,
ātaskā: āUpdate installed platforms, packages and librariesā,
āproblemMatcherā: [
ā$platformioā
The task will be ignored.
The commit you mentioned certainly looks like the problem.
1.8.0 worked fine (although I had to change some other code that is incompatible between 1.8.0 and 2.0.x (I access the main task to get the stack size and cont.h has changed).
After pio upgrade --dev, I canāt seem to access the platforms anymore; how do I roll back to release version?
What exact error message did you get? Do you have two PIO cores installed maybe? (VScode-internal and one externally installed via pip?)
When I try to access the platforms from PIO home, I just get the loading circle indefinitely. How do I get off the development branch?
(and no,Iāve installed nothing via pip)
Well thereās no integrated way to get back :S. Restart the IDE maybe? Iād just re-install the plugin from scratch if it doesnāt work.
Never mind, restarting VSCode cleared the problem with accessing the Platforms. Iāll try again with 1.8.0
platform = espressif8266@1.8.0 works as expected (properly with upload_port=COM5)
It fails with platform = espressif8266@2.0.0 or 2.0.1
ā¦and I think you nailed the problem commit. Is there any easy way for me to patch that locally until it gets resolved?
BTW, thanks so much for all of your help!
I think too. Now the real next question is why the python code socket.gethostbyname("COM5")
doesnāt throw a socket.error
exception for you, preventing an OTA upload. Can you ping COM5
or nslookup COM5
on the command line just for fun? Part of the problem is also that this is somehow a resolvable name for your PC.
When using the newer platform version youād have to manually fix the platform-espressif8266/builder/main.py
unfortunately
