Yes, nslookup of COM5 is successful (and I think we’d expected that based on the behavior and that bad commit). I think you had the right idea that there should be a new parameter upload_tool or something that allows you to specify esptool (should be default) or espota.
I’ll look into manually fixing main.py, but for now, I can work around by ensuring my target is the first serial port and commenting out the upload_port in platformio.ini
Thank you again for all of your help!!!
Can you please post that output and censor IP addresses if neccessary. I have a hard time believing this. For me it’s throwing
C:\Users\Maxi\Desktop\esp_test>nslookup COM7
Server: UnKnown
Address: fe80::eade:27ff:XXXX:XXXX
*** COM7 was not found by UnKnown: Non-existent domain.
Thank you @dalbert for … having the same problem?
It would seem that the problem rears it’s head dependent on the DNS setup of the user!
Here’s my output:
MacBook-Pro:WifiLEDController-Master lcotton$ dig "/dev/cu.usbserial-14413430"
; <<>> DiG 9.10.6 <<>> /dev/cu.usbserial-14413430
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32913
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;/dev/cu.usbserial-14413430. IN A
;; ANSWER SECTION:
/dev/cu.usbserial-14413430. 10 IN A 198.105.244.117
/dev/cu.usbserial-14413430. 10 IN A 198.105.254.17
;; Query time: 92 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Fri Mar 01 12:46:28 CST 2019
;; MSG SIZE rcvd: 76
I can see from the found IPs that my ISP has provided to my router the DNS servers that always returns a “found” response for any query, resulting in those ridiculous ad-filled “search” results page. Time to ignore DHCP-provided DNS servers…
What’s the proper way to submit a defect report on this? (or are you a pio dev and it’s already addressed?)
Depending on whether the problem is in the core or for one of the platforms (espressif8266
, avr
, …) you’d submit an issue on the core (Issues · platformio/platformio-core · GitHub) or the platform, e.g. Issues · platformio/platform-espressif8266 · GitHub. I’ve opened an issue, see
Officially resolved via this commit. You can now write upload_protocol = esptool
or upload_protocol = espota
, also the detection logic for hostnames has changed. Will be included in the next release.
This is a bug and was fixed in Release 2.0.2 · platformio/platform-espressif8266 · GitHub
Please update dev/platform via PlatformIO IDE > PIO Home > Platforms > Updates or using CLI $ pio update
See also updated docs Espressif 8266 — PlatformIO latest documentation
