As described in the topic, when i press “Upload and set fuses” is it not working, failing with the below log. If i do it in two separate steps, everything works?
platformio.exe run --target fuses --target upload <
> Executing task: C:\Users\XX\.platformio\penv\Scripts\platformio.exe run --target fuses --target upload <
Processing attiny85 (platform: atmelavr; board: attiny85; framework: arduino)
CONFIGURATION: h11ttps://docs.platformio.org/page/boards/atmelavr/attiny85.html
PLATFORM: Atmel AVR 2.0.0 > Generic ATtiny85
HARDWARE: ATTINY85 8MHz, 512B RAM, 8KB Flash
- framework-arduino-avr-attiny 1.3.2
- tool-avrdude 1.60300.190424 (6.3.0)
Found 10 compatible libraries
|-- <Bounce2> 2.53 (Z:\Projekter\PCB Projekter\MT-AUTORELAY\SOFTWARE\.pio\libdeps\attiny85\Bounce2_ID1106)
Selected fuses: [lfuse = 0xe2, hfuse = 0xdf, efuse = 0xff]
avrdude -p attiny85 -C C:\Users\XX\.platformio\packages\tool-avrdude\avrdude.conf -c stk500v2 -PCOM4 -Ulock:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xe2:m -Uefuse:w:0xff:m
MethodWrapper(["checkprogsize"], [".pio\build\attiny85\firmware.elf"])
RAM: [= ] 8.0% (used 41 bytes from 512 bytes)
Flash: [== ] 16.3% (used 1334 bytes from 8192 bytes)
.pio\build\attiny85\firmware.elf :
section size addr
.text 1326 0
.data 8 8388704
.bss 33 8388712
.comment 48 0
.note.gnu.avr.deviceinfo 60 0
.debug_info 1056 0
.debug_abbrev 1000 0
.debug_line 26 0
.debug_str 361 0
Total 3918
<lambda>(["upload"], [".pio\build\attiny85\firmware.hex"])
AVAILABLE: stk500v2
CURRENT: upload_protocol = stk500v2
BeforeUpload(["upload"], [".pio\build\attiny85\firmware.hex"])
avrdude -PCOM4 -v -p attiny85 -C C:\Users\XX\.platformio\packages\tool-avrdude\avrdude.conf -c stk500v2 -e -D -U flash:w:.pio\build\attiny85\firmware.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\XX\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : COM4
Using Programmer : stk500v2
avrdude: ser_open(): can't open device "\\.\COM4": Adgang nægtet.(Access denied)
avrdude done. Thank you.
*** [upload] Error 1
avrdude: stk500v2_command(): warning: Command timed out
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
*** [fuses] Error 1
