Any help with this problem greatly appreciated:
I have a project which has been under development for two years. It’s hosted on an AVR4809 which uses UPDI to progam.
On the machine where I develop and maintain the code, I do whatever I need and upload the code with a jtag2updi programmer which is an Arduino Uno with the Jtag2UPDI code on it. It all works fine. My code is managed by Git. I do the Push & Pull thing. It’s great exercise. ![]()
So on my operational machine in a remote field with no mains power or internet, I have PIO installed and my Git repos pulled. My code compiles which I appreciate. However, PIO has not heard of jtag2updi on this machine. It’s an Intel NUC. I brought it home & connected it to internet world. It was fine. However it still complains that Jtag2updi is ‘not a valid programmer’. I use the same Arduino uno programmer with no changes. Any help much appreciated. Here’s the output from the upload window below, followed by the PIO.ini
Thanks for help.
AVAILABLE: custom
CURRENT: upload_protocol = custom
Uploading .pio\build\Upload_UPDI\firmware.hex
avrdude: Can't find programmer id "jtag2updi"
Valid programmers are:
2232HIO = FT2232H based generic programmer
4232h = FT4232H based generic programmer
arduino = Arduino
arduino-ft232r = Arduino: FT232R connected to ISP
arduinoisp = Arduino ISP Programmer
arduinoisporg = Arduino ISP Programmer
atmelice = Atmel-ICE (ARM/AVR) in JTAG mode
atmelice_dw = Atmel-ICE (ARM/AVR) in debugWIRE mode
atmelice_isp = Atmel-ICE (ARM/AVR) in ISP mode
atmelice_pdi = Atmel-ICE (ARM/AVR) in PDI mode
avr109 = Atmel AppNote AVR109 Boot Loader
avr910 = Atmel Low Cost Serial Programmer
avr911 = Atmel AppNote AVR911 AVROSP
avrftdi = FT2232D based generic programmer
avrisp = Atmel AVR ISP
avrisp2 = Atmel AVR ISP mkII
avrispmkII = Atmel AVR ISP mkII
avrispv2 = Atmel AVR ISP V2
buspirate = The Bus Pirate
buspirate_bb = The Bus Pirate (bitbang interface, supports TPI)
butterfly = Atmel Butterfly Development Board
butterfly_mk = Mikrokopter.de Butterfly
bwmega = BitWizard ftdi_atmega builtin programmer
C232HM = FT232H based module from FTDI and Glyn.com.au
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts
dasa = serial port banging, reset=rts sck=dtr mosi=txd miso=cts
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts
diecimila = alias for arduino-ft232r
dragon_dw = Atmel AVR Dragon in debugWire mode
dragon_hvsp = Atmel AVR Dragon in HVSP mode
dragon_isp = Atmel AVR Dragon in ISP mode
dragon_jtag = Atmel AVR Dragon in JTAG mode
dragon_pdi = Atmel AVR Dragon in PDI mode
dragon_pp = Atmel AVR Dragon in PP mode
flip1 = FLIP USB DFU protocol version 1 (doc7618)
flip2 = FLIP USB DFU protocol version 2 (AVR4023)
ft232r = FT232R Synchronous BitBang
ft245r = FT245R Synchronous BitBang
jtag1 = Atmel JTAG ICE (mkI)
jtag1slow = Atmel JTAG ICE (mkI)
jtag2 = Atmel JTAG ICE mkII
jtag2avr32 = Atmel JTAG ICE mkII im AVR32 mode
jtag2dw = Atmel JTAG ICE mkII in debugWire mode
jtag2fast = Atmel JTAG ICE mkII
jtag2isp = Atmel JTAG ICE mkII in ISP mode
jtag2pdi = Atmel JTAG ICE mkII PDI mode
jtag2slow = Atmel JTAG ICE mkII
jtag3 = Atmel AVR JTAGICE3 in JTAG mode
jtag3dw = Atmel AVR JTAGICE3 in debugWIRE mode
jtag3isp = Atmel AVR JTAGICE3 in ISP mode
jtag3pdi = Atmel AVR JTAGICE3 in PDI mode
jtagkey = Amontec JTAGKey, JTAGKey-Tiny and JTAGKey2
jtagmkI = Atmel JTAG ICE (mkI)
jtagmkII = Atmel JTAG ICE mkII
jtagmkII_avr32 = Atmel JTAG ICE mkII im AVR32 mode
lm3s811 = Luminary Micro LM3S811 Eval Board (Rev. A)
mib510 = Crossbow MIB510 programming board
mkbutterfly = Mikrokopter.de Butterfly
nibobee = NIBObee
o-link = O-Link, OpenJTAG from www.100ask.net
openmoko = Openmoko debug board (v3)
pavr = Jason Kyle's pAVR Serial Programmer
pickit2 = MicroChip's PICkit2 Programmer
ponyser = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts
siprog = Lancos SI-Prog <http://www.lancos.com/siprogsch.html>
stk500 = Atmel STK500
stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode
stk500pp = Atmel STK500 V2 in parallel programming mode
stk500v1 = Atmel STK500 Version 1.x firmware
stk500v2 = Atmel STK500 Version 2.x firmware
stk600 = Atmel STK600
stk600hvsp = Atmel STK600 in high-voltage serial programming mode
stk600pp = Atmel STK600 in parallel programming mode
ttl232r = FTDI TTL232R-5V with ICSP adapter
tumpa = TIAO USB Multi-Protocol Adapter
UM232H = FT232H based module from FTDI and Glyn.com.au
uncompatino = uncompatino with all pairs of pins shorted
usbasp = USBasp, http://www.fischl.de/usbasp/
usbasp-clone = Any usbasp clone with correct VID/PID
usbtiny = USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
wiring = Wiring
xplainedmini = Atmel AVR XplainedMini in ISP mode
xplainedmini_dw = Atmel AVR XplainedMini in debugWIRE mode
xplainedpro = Atmel AVR XplainedPro in JTAG mode
*** [upload] Error 1
======================================================================== [FAILED] Took 3.72 seconds ========================================================================
Environment Status Duration
Upload_UPDI FAILED 00:00:03.716
pio.ini
[platformio]
default_envs = Upload_UPDI
[env]
platform = atmelmegaavr
board = ATmega4809
board_build.f_cpu = 16000000L
board_hardware.oscillator = internal
board_build.variant = 40pin-standard
build_unflags =
monitor_port = COM49
monitor_speed = 19200
monitor_echo = on
lib_extra_dirs =
C:\Users\Paul\Documents\PlatformIO\Projects\Live
waspinator/AccelStepper@^1.61
qub1750ul/SoftwareReset@^3.0.0
[env:Upload_UPDI]
;upload_port = COM24
upload_flags =
-C
-p
$BOARD_MCU
-c
jtag2updi
-P
;NB the board MUST BE POWERED for upload to work
COM9
-b
115200
[env:fuses_bootloader]
extends = env:Upload_UPDI
board_hardware.bod = 2.7v
board_hardware.eesave = yes
board_hardware.uart = no_bootloader
board_hardware.rstpin = reset
