Updating ESP32 Platform / Arduino Framework
I am trying to resolve a BLE problem and wanted to update to the latest stable ESP32 Arduino Framework :
ESP32 Arduino Release 1.0.6 based on ESP-IDF v3.3.5
But I cant see how to do that. Instead I followed the next best thing and updated the ESP32 platform to ESP 3.2.1 as the ‘Platform button’ allowed.
Now I compile and get incompatible pointer errors!
So, How should I update the Arduino ‘Framework’ to 1.06? and is it the same as updating the ESP32 ‘Platform’?
And what to do about those errors?
.. platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
..platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                 uint8_t * last_out8 = &result[c_longs-1];
..platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                 uint8_t * last_data8 = &last_data;
Careful, the platform version does not correspond to the Arduino core version. They are completely separate. In the release page you can see that e.g. platform-espressif32 3.2.0 uses Arduino core version 1.0.6, and so does the most recent 3.2.1.
So if you use a standard
while having the latest Espressif32 version installed / updated to, you will get in the compilation output
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.2.1) > Espressif ESP32 Dev Module
 - framework-arduinoespressif32 3.10006.210326 (1.0.6)
 - tool-esptoolpy 1.30000.201119 (3.0.0)
 - toolchain-xtensa32 2.50200.97 (5.2.0)
while shows you that the core version 1.0.6 is already the used one.
Nothing, they’re just a warning and the resulting code will work. Also it is already fixed for the next framework version. If it really bothers you can put the explicit (uint8_t*) cast in there.
Side note: this thread is related to the new feature requests at Feature request: allow to specify in a project a specific framework version · Issue #3972 · platformio/platformio-core · GitHub, the ability to specify the required versions as part of the checked in project specification.
Thanks for that.
I did update Platform to 3.2.1 as allowed by the ‘Update Platform’ Button, but now the button just says ‘Uninstall’
I saw the release 3.2.1 uses Arduino core 1…0.6 but still have no idea how to update to THAT later platform so I get to run with 1.0.6.
Yes that’s the most recent version, so no update available then :smiley:
As said above, if you are running the latest platform-espressif32 you will get the package framework-arduinoespressif32 of version 1.0.6 automatically with it. No special configuration required.
When you specify
in the platformio.ini it will take the latest Espressif32 platform that you have installed in PlatformIO. The documentation also tells you have to force a different version by e.g. specifying
platform = espressif32@3.2.1
(that of course has the disadvantage that this project will not simply use the latest ESP32 platform that is installed but that fixed version – so no ‘autoupdate’.)
Right. I’m confusing myself.
Thanks!
