PlatformIO supports the SODAQ SFF Board series. However, the provided package is severely outdated and the manufacturer provides current ArduinoCore-samd via Github (Commits · SodaqMoja/SodaqCore-samd · GitHub). What are the appropriate steps to update the PlatformIO package for that board?
Alternatively: Can I bypass PlatformIO’s integrated board configuration and supply a local clone of the board files to my PlatformIO project?
In general, the procedure is to first request an update of the package (framework-arduino-samd-sodaq here) in the appropriate platform – that is Issues · platformio/platform-atmelsam · GitHub here.
If that is not quick enough, you can either:
locally replace the framework files in C:\Users\<user>\.platformio\packages\framework-arduino-samd-sodaq with the latest version
use a platform_packages expression to point to a new source for the framework-arduino-samd-sodaq, e.g. a github forked repository with a package.json in it), e.g. with a platformio.ini of
you get the 1.8.6-sodaq Arduino core version that I have forked (simple fork + package.json add)
The JSON board configuration files can be supplied via a project-local folder boards as per documentation and documentation.
In most cases that is however unnecessary since the manifest can be changed on the fly in the platformio.ini. If you are e.g. working with board = sodaq_one, then that uses sodaq_one.json, and if you don’t like a value in that, it can be overwritten, so e.g.
would remap the build information to use the ArduinoCore-SAMD with the arduino_zero variant (which might not make a lot of sense of course, just for illustration purposes).
Thanks @maxgerhardt - also for directing me to your fork. (Currently I am running a hand-patched version of the SODAQ-Core in \framework-arduino-samd-sodaq but that is getting cumbersome …).
