Hello there,
I’m completely new about unit testing. I’m trying to learn creating them on something easy, so I chose Arduino Uno as experimental device. I followed the tutorial: https://www.youtube.com/watch?v=_xRv-3FWyLE&ab_channel=TomaszTarnowski But I have never been able to complete it due to massive amount of error. First set of error has been solved by installing gcc compiler I used mingw-w64: MinGW-w64 - for 32 and 64 bit Windows - Browse /mingw-w64 at SourceForge.net , but another sets of error appears:
.pio\libdeps\native\googletest\googletest\include/gtest/internal/gtest-port.h:1235:8: error: ‘mutex’ in namespace ‘std’ does not name a type
std::mutex mu_;
These errors came from the version of googletest so I changed the setting in platformio.ini from version 12:
lib_deps = google/googletest@1.12.0
to version 10:
lib_deps = google/googletest@1.10.0
unfortunately, there was still errors while trying to compile program for Arduino, because the compiler cannot compile the google test. I removed the library dependency from platformio.ini:
platformio.ini
[env:uno]
board = uno
test_ignore =
test_desktop
test_embedded[env:native]
platform = native
test_ignore =
test_embedded
lib_compat_mode = off
build_flags = -std=c++11
and change the setting for compiling in the bottom bar from Default (nameOfProject) to env:uno (nameOfProject)
than I have been able to compile program for Arduino And run an empty test
But when I try adding constructor of tested class into TEST method then following error appears:
.pio\build\native\test\test_desktop\LedDiodeTest.o:LedDiodeTest.cpp:(.text+0x13e): undefined reference to
LedDiode::LedDiode()' .pio\build\native\test\test_desktop\LedDiodeTest.o:LedDiodeTest.cpp:(.text+0x14a): undefined reference toLedDiode::blick()’
My code:
src/LedDiode.hpp
#ifndef MY_LED_DIODE_H
#define MY_LED_DIODE_H
#include “IBSP.hpp”class LedDiode
public:
LedDiode();
void init(IBSP* hw, uint8_t pin) ;
void setState(uint8_t state) ;
void blick() ;
private:
IBSP* HW;
};#endif
src/LedDiode.cpp
#include “LedDiode.hpp”
LedDiode::LedDiode(){
void LedDiode::init(IBSP* hw, uint8_t pin){
this->HW = hw;
hw->pinDir(pin,IBSP::OUT);
}void LedDiode::setState(uint8_t state){
void LedDiode::blick(){
Src/IBSP.hpp
#ifndef IBSP_H
#define IBSP_H
#include <stdint.h>class IBSP
public:
enum{
OUT = (uint8_t)1,
IN = (uint8_t)0
virtual void pinDir(uint8_t pin, uint8_t value) = 0;
virtual void setPin(uint8_t pin, uint8_t value) = 0;
virtual uint8_t getPin(uint8_t pin) = 0;
virtual unsigned long now() = 0;
private:
};#endif
test/LedDiodeTest.cpp
#include “mocks/MockBSP.h”
#include <gtest/gtest.h>
#include “LedDiode.hpp”TEST(ledDiode, check_pin_while_creating_diode)
MockBSP bsp;//EXPECT_CALL(bsp,pinDir(13,IBSP::OUT)); //EXPECT_CALL(bsp,setPin(13,IBSP::OUT)); LedDiode mydiode; //mydiode.init(&bsp,13); mydiode.blick(); EXPECT_TRUE(true);}
test/test_desktop/mock/MockBSP.h
#include “gmock/gmock.h”
#include “IBSP.hpp”class MockBSP : public IBSP
public:
MOCK_METHOD(void,
pinDir,
(uint8_t pin, uint8_t value),
(override)
MOCK_METHOD(void,
setPin,
(override)
MOCK_METHOD(uint8_t,getPin, (uint8_t pin),(override));
MOCK_METHOD(unsigned long,now,(),(override));
I also installed python 3.10.5, because I reed somewhere it is necessary, but nothing changed.
Could you give me an advice please what did I wrong? And also, is it possible somehow use the googletest inside Arduino?
Thank you
Rytirj
