Is this a library issue? Excuse the massive code dump.
* Executing task in folder Waveshare_Weather: platformio run
## Processing esp32dev (board: esp32dev; platform: espressif32; framework: arduino)
PLATFORM: Espressif 32 (6.12.0) > Espressif ESP32 Dev Module
* framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
* tool-esptoolpy @ 2.40900.250804 (4.9.0)
* toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Converting Waveshare_7_5_T7.ino
LDF: Library Dependency Finder → https://bit.ly/configure-pio-ldf
LDF Modes: Finder \~ chain, Compatibility \~ soft
Found 38 compatible libraries
Scanning dependencies…
|-- Adafruit EPD @ 4.6.6
|-- GxEPD2 @ 1.6.5
|-- U8g2_for_Adafruit_GFX @ 1.8.0
|-- SPI @ 2.0.0
|-- WiFi @ 2.0.0
|-- HTTPClient @ 2.0.0
Compiling .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o
Linking .pio/build/esp32dev/firmware.elf
/Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o:(.literal.\_Z28Convert_Readings_to_Imperialv+0x8): undefined reference to `hPa_to_inHg(float)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o:(.literal._Z28Convert_Readings_to_Imperialv+0xc): undefined reference to `mm_to_inches(float)’
/Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o:(.literal.\_Z8DrawMooniiiii6String+0x18): undefined reference to `NormalizedMoonPhase(int, int, int)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o:(.literal._Z22DisplayForecastSectionii+0x54): undefined reference to `SumOfPrecip(float\*, int)’
/Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o: in function `Convert_Readings_to_Imperial()': /Users/toatess/Desktop/Waveshare_Weather/src/forecast_record.h:36: undefined reference to `hPa_to_inHg(float)’
/Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /Users/toatess/Desktop/Waveshare_Weather/src/forecast_record.h:36: undefined reference to `mm_to_inches(float)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o: in function `Convert_Readings_to_Imperial()‘:
/Users/toatess/Desktop/Waveshare_Weather/src/common.h:15: undefined reference to `mm_to_inches(float)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o: in function `DrawMoon(int, int, int, int, int, String)’:
/Users/toatess/Desktop/Waveshare_Weather/src/Waveshare_7_5_T7.ino:305: undefined reference to `NormalizedMoonPhase(int, int, int)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/src/Waveshare_7_5_T7.ino.cpp.o: in function `DisplayForecastSection(int, int)‘:
/Users/toatess/Desktop/Waveshare_Weather/src/Waveshare_7_5_T7.ino:400: undefined reference to `SumOfPrecip(float*, int)' /Users/toatess/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /Users/toatess/Desktop/Waveshare_Weather/src/Waveshare_7_5_T7.ino:400: undefined reference to `SumOfPrecip(float\*, int)’
\*\*\* \[.pio/build/esp32dev/firmware.elf\] Error 1
=================================== \[FAILED\] Took 4.65 seconds ===================================
* The terminal process “platformio ‘run’” terminated with exit code: 1.
