I cannot uplodad any code on my Nucleo-L476RG. It worked well before, I could upload and debug with sucess, but it does not works anymore and I cannot not say what I did since. I have tried to press the reset button and it is also not working.
The terminal :
indent preformatted text by 4 spacesProcessing nucleo_l476rg (platform: ststm32; board:
nucleo_l476rg; framework: stm32cube)
--------------------------------------------------------------------------------------------Verbose mode can be enabled
via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_l476rg.html
PLATFORM: ST STM32 (12.0.0) > ST Nucleo L476RG
HARDWARE: STM32L476RGT6 80MHz, 128KB RAM, 1MB Flash
- framework-stm32cubel4 1.16.0
- tool-dfuutil 1.9.200310
- tool-ldscripts-ststm32 0.1.0
- tool-openocd 2.1000.200630 (10.0)
- tool-stm32duino 1.0.2
Found 52 compatible libraries
Checking size .pio\build\nucleo_l476rg\firmware.elf
RAM: [ ] 0.1% (used 140 bytes from 131072 bytes)
Flash: [ ] 0.7% (used 6900 bytes from 1048576 bytes)
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
Uploading .pio\build\nucleo_l476rg\firmware.elf
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
Error executing event examine-end on target stm32l4x.cpu:
embedded:startup.tcl:279: Error:
in procedure 'program'
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 279
xPSR: 0x01000000 pc: 0x08001ba0 msp: 0x20018000
** Programming Started **
Warn : Adding extra erase range, 0x08001c88 .. 0x08001fff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
*** [upload] Error 1
================================================================================================== [FAILED] Took 4.47 seconds ==================================================================================================
Does someone already had this? : Error executing event examine-end on target stm32l4x.cpu:
Thanks for help
