Trouble embedding binary files in ESP-IDF (component.mk) using PlatformIO
Hi, Using the ESP-IDF framework in PlatformIO, I’m trying to get binary files to be linked in to objects using the component.mk directive: COMPONENT_EMBED_FILES. But it seems that PlatformIO is ignoring component.mk files in my project hierarchy.
The structure of my project is:
Project
|->components
| |->component.mk
| |->sound.wav
|->lib
|->src
| |->main.c
| |->sdkconfig.h
The contents of component.mk is simply: COMPONENT_EMBED_FILES := sound.wav
The main.c files references the binary object as by creating an external reference to it as shown below:
extern const uint8_t sound_wav_start[] asm(“_binary_sound_wav_start”);
extern const uint8_t sound_wav_end[] asm(“_binary_sound_wav_end”);
Has anyone had success including binary files in their project under PlatformIO using the ESP-IDF framework?
Thanks
You need Espressif 32 — PlatformIO latest documentation
@wrox have you figured out how? ivankravets’ response is rather vague
Which flag exactly? espidf.py does not contain COMPONENT_EMBED_FILES. Works in ESP-IDF but not in PlatformIO for me.
Could you provide full output from ESP-IDF without PIO how does it work? Need to understand how do they handle COMPONENT_EMBED_FILES
I’m trying to use an ESP-IDF library which has a component.mk containing a list of files to be embedded in the build as follows:
COMPONENT_EMBED_FILES := style.css jquery.gz code.js index.html
I’m getting compile errors when trying to include this library in my project:
.pioenvs/esp32dev/src/http_server.o:(.literal.http_server_netconn_serve+0x4c): undefined reference to `_binary_style_css_start’
*** [.pioenvs/esp32dev/firmware.elf] Error 1
How to tell the compiler, tell PlatformIO to link these assests?
Hallo
I am new to this forum, but the troubles with PlatformIO to treat the “component.mk” Files has forced to register me
I build the project with esp-idf @janoist1 refers to:
Building with PlatformIO gives the errors of the previous post
here are the relevant lines i greped out
$ make > make.txt 2>&1
$ grep -C 7 index.html make.txt
CC build/main/http_server.o
CC build/main/wifi_manager.o
CC build/main/main.o
CC build/main/json.o
EMBED build/main/style.css.bin.o
EMBED build/main/jquery.gz.bin.o
EMBED build/main/code.js.bin.o
EMBED build/main/index.html.bin.o
AR build/main/libmain.a
CC build/mbedtls/library/ecp_curves.o
CC build/mbedtls/library/sha512.o
CC build/mbedtls/library/pkcs12.o
CC build/mbedtls/library/ccm.o
CC build/mbedtls/library/pkcs5.o
CC build/mbedtls/library/pk.o
@ivankravets Watever you need to fix the issue with the component.mk File you get it
beacause the espidf-framework in PlatformIO is useless for Projects with embedded Files (like picures, json.js, certs …)
Excuse my bad english
Best regards
Michael
Hello again
I have trouble with a Link in my post (maximum 2 Links per post)
So here is the complete make run at pastebin of the Project janoist1 refers to
on pastebin → make run wifi-manager - Pastebin.com
There is another post with a simular Problem
Best regards
Michael
Was this ever resolved? I have almost exactly the same problem, and SPIFFS doesn’t seem to be the solution.
Edit: Found the solution over on Espressif 32 — PlatformIO latest documentation , which is a different topic than the one previously linked
