Yes, that works perfectly fine.
I guess I need to stay in an unofficial branch for a while.
Do you have it in the roadmap?
Should this work now properly without any custom branches? =)
Does not work here on my side
[env]
#board_build.partitions = default_8MB.csv
-DARDUINO_ARCH_ESP32
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
once I uncomment the default_8MB.csv
line, the device will not boot anymore and prints errors that it cannot boot…
The “percentage” updates… but that doesnt help if its not booting
With which settings does it work in the Arduino IDE?
Thanks Max,
I don’t know, I don’t use the Arduino IDE
VS-Code + PlatformIO
Well does your board have 8MB flash? Pleas execute <python> esptool.py flash_id
in accordance to Upload failed on esp-wrover-kit (framework = arduino, espidf) - #2 by maxgerhardt and post the output here.
As you already posted above, I am using the ESP32-pico-v3-02.
This chip has 8MB built in.
esptool.py v4.2.1
Found 2 serial ports
Serial port /dev/ttyUSB0
Connecting.....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting.....
Detecting chip type... ESP32
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:83:98:d1:a6:44
Uploading stub...
Running stub...
Stub running...
Manufacturer: 68
Device: 4017
Detected flash size: 8MB
Hard resetting via RTS pin...
build script says 4MB?
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-mkfatfs @ 2.0.1
- tool-mklittlefs @ 1.203.210628 (2.3)
- tool-mkspiffs @ 2.230.0 (2.30)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
Found 41 compatible libraries
|-- SPI @ 2.0.0
|-- WiFi @ 2.0.0
|-- LittleFS @ 2.0.0
| |-- FS @ 2.0.0
|-- ArduinoJson @ 6.19.4
|-- ESPAsyncDNSServer @ 1.0.0+sha.89e6db8
| |-- ESP32 Async UDP @ 2.0.0
|-- ESPAsync_WiFiManager @ 1.15.0+sha.d45153b
| |-- AsyncTCP @ 1.1.1
| |-- ESP Async WebServer @ 1.2.3
| | |-- AsyncTCP @ 1.1.1
| | |-- FS @ 2.0.0
| | |-- WiFi @ 2.0.0
| |-- ESP_DoubleResetDetector @ 1.3.2
| |-- WiFi @ 2.0.0
|-- NeoPixelBus @ 2.7.0
| |-- SPI @ 2.0.0
|-- AsyncMqttClient @ 0.9.0
| |-- AsyncTCP @ 1.1.1
|-- HTTPClient @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- WiFiClientSecure @ 2.0.0
| | |-- WiFi @ 2.0.0
|-- HTTPUpdate @ 2.0.0
| | |-- WiFi @ 2.0.0
| | | |-- WiFi @ 2.0.0
| |-- Update @ 2.0.0
| |-- WiFi @ 2.0.0
|-- FS @ 2.0.0
Retrieving maximum program size .pio/build/release/firmware.elf
Checking size .pio/build/release/firmware.elf
RAM: [== ] 16.0% (used 52460 bytes from 327680 bytes)
Flash: [========= ] 94.5% (used 1239105 bytes from 1310720 bytes)
What are the exact bootloader messages at 115200 baud after you flash it with the 8MB partition table?
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 271414342, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
ets Jul 29 2019 12:21:46
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
Please install the Arduino IDE + Arduino-ESP32 2.0.5 core and test with the same configuration (done via the Arduino IDE → Tools menu). That way we know whether PlatformIO is at fault or the core itself.
Did you also try the simplest possible blink + print sketch in PlatlformIO with the 8MByte partition table? Your sketch seems quite extensive.
this works… at least does not crash
but I have no clue what they exactly do? can find any settings saved anywhere… this IDE is horrible
Then let’s equalize the settings accoding to the docs. Can you use the following platformio.ini
[env]
; PSRAM: "Enabled"
; Core Debug Level: "Verbose"
-DBOARD_HAS_PSRAM
-DCORE_DEBUG_LEVEL=5
; Partition Scheme: "8M with spiffs"
; Flash Mode: "QIO"
board_build.flash_mode = qio
; upload + monitor sports and speed
And use the exact some source code as in the Arduino IDE in your src/main.cpp
stripped it down…
platformio result is:
RAM: [= ] 5.0% (used 16520 bytes from 327680 bytes)
Flash: [= ] 7.7% (used 257305 bytes from 3342336 bytes)
and arduino result is
Sketch uses 262409 bytes (7%) of program storage space. Maximum is 3342336 bytes.
Global variables use 16520 bytes (5%) of dynamic memory, leaving 311160 bytes for local variables. Maximum is 327680 bytes.
so its very close… but still crashing
What are the bootloader messages after flashing it with the Arduino IDE but opening the serial monitor in PlatformIO and pressing the reset button?
now its not working either using the Arduino IDE…
The IDE now prints some weird warning too
Configuring flash size...
Erasing flash (this may take a while)...
Chip erase completed successfully in 1.9s
Warning: Image file at 0x1000 is protected with a hash checksum, so not changing the flash size setting. Use the --flash_size=keep option instead of --flash_size=8MB in order to remove this warning, or use the --dont-append-digest option for the elf2image command in order to generate an image file without a hash checksum
Compressed 18880 bytes to 13027...
Writing at 0x00001000... (100 %)
Wrote 18880 bytes (13027 compressed) at 0x00001000 in 0.2 seconds (effective 649.1 kbit/s)...
load:0x3fff0030,len:1344
load:0x40078000,len:13836
load:0x40080400,len:3608
entry 0x400805f0
entry 0x400805f0
entry 0x400805f0
entry 0x400805f0
okay… here is the bootloader startup using the ARDUINO build:
huhu
huhu
huhu
huhu
huhu
huhu
huhu
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805f0
[ 4][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 228][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
huhu
huhu
huhu
huhu
huh
PS: I cant write new replies… maybe I can edit this one
TEST!
BTW: … arduino was NOT working as long the content of that ZIP were within the sketch folder
… startup platformio using the default partitions …
entry 0x400805f0
You seem to be running in weird bugs here. If you can consistently reproduce the faul within the Arduino IDE, file an issue at Issues · espressif/arduino-esp32 · GitHub. Otherwise, if the issue persists in PlatformIO, file an issue in Issues · platformio/platform-espressif32 · GitHub.
I can consistently make it work with arduino but can’t make it work with platformio.
thanks for your assistance max!
I will file an issue and link this discussion though
hope we can find a solution
