I am recently trying out ESP32-PICO-V3-02 chip but I noticed this board is not listed in PlatformIO.
So I am wondering how I can unlock the real 8MB flash and internal PS-RAM probably.
Per schematics it’s just an ESP32 with 8MB flash + 2 MByte PSRAM chip (https://www.espressif.com/sites/default/files/documentation/esp32-pico-v3-02_datasheet_en.pdf).
Have you tried
boad = esp32dev
board_build.partitions = default_8MB.csv
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
? (docs)
Thanks for your reply.
I think I managed to use the 8MB flash using your suggestion.
But I am guessing I need the latest Ardunio core to get access to the PS-RAM, otherwise, the MCU keeps rebooting with the following error code.
E (180) psram: Not a valid or known package id: 6
abort() was called at PC 0x40084f87 on core 0ELF file SHA256: 0000000000000000
Backtrace: 0x40089788:0x3ffbbaf0 0x400899f9:0x3ffbbb10 0x40084f87:0x3ffbbb30 0x400ebb25:0x3ffbbb60 0x400d5a9f:0x3ffbbb80 0x400d59dd:0x3ffbbba0 0x400d72dc:0x3ffbbbc0 0x400ebc9e:0x3ffbbbf0 0x4008a9fd:0x3ffbbc10
Rebooting…
Do you know which version of Ardunio is used in Platform-Espressif32 v3.5.0?
It’s the older 1.0.6 version.
Can you try setting
platform = https://github.com/Jason2866/platform-espressif32.git
instead in the platformio.ini?
Yes, that works perfectly fine.
I guess I need to stay in an unofficial branch for a while.
Do you have it in the roadmap?
Should this work now properly without any custom branches? =)
Does not work here on my side
[env]
#board_build.partitions = default_8MB.csv
-DARDUINO_ARCH_ESP32
-DBOARD_HAS_PSRAM
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
once I uncomment the default_8MB.csv line, the device will not boot anymore and prints errors that it cannot boot…
The “percentage” updates… but that doesnt help if its not booting
With which settings does it work in the Arduino IDE?
Thanks Max,
I don’t know, I don’t use the Arduino IDE
VS-Code + PlatformIO
Well does your board have 8MB flash? Pleas execute <python> esptool.py flash_id in accordance to Upload failed on esp-wrover-kit (framework = arduino, espidf) - #2 by maxgerhardt and post the output here.
As you already posted above, I am using the ESP32-pico-v3-02.
This chip has 8MB built in.
esptool.py v4.2.1
Found 2 serial ports
Serial port /dev/ttyUSB0
Connecting.....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting.....
Detecting chip type... ESP32
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:83:98:d1:a6:44
Uploading stub...
Running stub...
Stub running...
Manufacturer: 68
Device: 4017
Detected flash size: 8MB
Hard resetting via RTS pin...
build script says 4MB?
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-mkfatfs @ 2.0.1
Found 41 compatible libraries
|-- SPI @ 2.0.0
|-- WiFi @ 2.0.0
|-- LittleFS @ 2.0.0
| |-- FS @ 2.0.0
|-- ArduinoJson @ 6.19.4
|-- ESPAsyncDNSServer @ 1.0.0+sha.89e6db8
| |-- ESP32 Async UDP @ 2.0.0
|-- ESPAsync_WiFiManager @ 1.15.0+sha.d45153b
| |-- AsyncTCP @ 1.1.1
| |-- ESP Async WebServer @ 1.2.3
| | |-- AsyncTCP @ 1.1.1
| | |-- FS @ 2.0.0
| | |-- WiFi @ 2.0.0
| |-- ESP_DoubleResetDetector @ 1.3.2
| |-- WiFi @ 2.0.0
|-- NeoPixelBus @ 2.7.0
| |-- SPI @ 2.0.0
|-- AsyncMqttClient @ 0.9.0
| |-- AsyncTCP @ 1.1.1
|-- HTTPClient @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- WiFiClientSecure @ 2.0.0
| | |-- WiFi @ 2.0.0
|-- HTTPUpdate @ 2.0.0
| | |-- WiFi @ 2.0.0
| | | |-- WiFi @ 2.0.0
| |-- Update @ 2.0.0
| |-- WiFi @ 2.0.0
|-- FS @ 2.0.0
Retrieving maximum program size .pio/build/release/firmware.elf
Checking size .pio/build/release/firmware.elf
RAM: [== ] 16.0% (used 52460 bytes from 327680 bytes)
Flash: [========= ] 94.5% (used 1239105 bytes from 1310720 bytes)
What are the exact bootloader messages at 115200 baud after you flash it with the 8MB partition table?
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 271414342, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
ets Jul 29 2019 12:21:46
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
entry 0x400805e4
Please install the Arduino IDE + Arduino-ESP32 2.0.5 core and test with the same configuration (done via the Arduino IDE → Tools menu). That way we know whether PlatformIO is at fault or the core itself.
Did you also try the simplest possible blink + print sketch in PlatlformIO with the 8MByte partition table? Your sketch seems quite extensive.
this works… at least does not crash
but I have no clue what they exactly do? can find any settings saved anywhere… this IDE is horrible ![]()
Then let’s equalize the settings accoding to the docs. Can you use the following platformio.ini:
[env]
; PSRAM: "Enabled"
; Core Debug Level: "Verbose"
-DBOARD_HAS_PSRAM
-DCORE_DEBUG_LEVEL=5
; Partition Scheme: "8M with spiffs"
; Flash Mode: "QIO"
board_build.flash_mode = qio
; upload + monitor sports and speed
And use the exact some source code as in the Arduino IDE in your src/main.cpp.
stripped it down…
platformio result is:
RAM: [= ] 5.0% (used 16520 bytes from 327680 bytes)
Flash: [= ] 7.7% (used 257305 bytes from 3342336 bytes)
and arduino result is
Sketch uses 262409 bytes (7%) of program storage space. Maximum is 3342336 bytes.
Global variables use 16520 bytes (5%) of dynamic memory, leaving 311160 bytes for local variables. Maximum is 327680 bytes.
so its very close… but still crashing
built outputs: Deleted
What are the bootloader messages after flashing it with the Arduino IDE but opening the serial monitor in PlatformIO and pressing the reset button?
