I am having troubles using the ESP32-PICO-V3-02 with the full flash size of 8MB.…
Using the "default.csv" is working fine, but when switching to the "default_8mb.csv" it does not boot any more.. :(
I already had a short chat with @maxgerhardt (thanks again!) [here](https://community.platformio.org/t/support-for-eps32-pico-v3/26967/23?u=slaesh) and he suggested me to file an issue here :)
# repo to reproduce
https://github.com/slaesh/eps32-pico-v3-8mb-flash-issue
# logs using platformio
using platformio and the default partition table, a reset looks like this
huhu
huhu
huhu
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 271414342, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1344
load:0x40078000,len:13836
load:0x40080400,len:3608
entry 0x400805f0
[ 4][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[ 228][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
huhu
huhu
huhu
huhu
using platformio and the 8mb partition table, this error loops around:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805f0
entry 0x400805f0
entry 0x400805f0
entry 0x400805f0
entry 0x400805f0
# platformio version used
# artefacts platformio
[platformio_output_8mb.zip](https://github.com/platformio/platform-espressif32/files/9885887/platformio_output_8mb.zip)
[platformio_output_default.zip](https://github.com/platformio/platform-espressif32/files/9885897/platformio_output_default.zip)
# logs using arduino ide
Sketch uses 262409 bytes (7%) of program storage space. Maximum is 3342336 bytes.
Global variables use 16520 bytes (5%) of dynamic memory, leaving 311160 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:83:98:d1:a6:44
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Erasing flash (this may take a while)...
Chip erase completed successfully in 4.5s
Compressed 18880 bytes to 13028...
Writing at 0x00001000... (100 %)
Wrote 18880 bytes (13028 compressed) at 0x00001000 in 0.2 seconds (effective 648.2 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 129...
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.0 seconds (effective 1699.2 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 2616.9 kbit/s)...
Compressed 262800 bytes to 143222...
Writing at 0x00010000... (11 %)
Writing at 0x0001ceb2... (22 %)
Writing at 0x00024e82... (33 %)
Writing at 0x0002a2df... (44 %)
Writing at 0x0002f640... (55 %)
Writing at 0x00037ee7... (66 %)
Writing at 0x00040e33... (77 %)
Writing at 0x00046839... (88 %)
Writing at 0x0004befe... (100 %)
Wrote 262800 bytes (143222 compressed) at 0x00010000 in 2.0 seconds (effective 1057.6 kbit/s)...
serial output arduino ide
huhu
huhu
huhu
huhu
huhu
entry 0x400805f0
huhu
huhu
huhu
huhu
# arduino version used
[arduino_output.zip](https://github.com/platformio/platform-espressif32/files/9885908/arduino_output.zip)
