I’ve been trying to get my debugger working with my mega2560, and I could use some help. Whenever I run the debugger, I get the following error:
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
Bogus trace status reply from target: timeout
My platformio.ini file is as follows
[env:megaatmega2560]
board = megaatmega2560
board_build.f_cpu = 2000000L
debug_tool = avr-stub
debug_port = COM7
lib_deps = jdolinay/avr-debugger @ ~1.4
I uninstalled VSCode and reinstalled it, and still couldn’t get it to work. I created a new project where I copy and pasted the code given on the configuration page
#include "avr8-stub.h"
#include "app_api.h" // only needed with flash breakpoints
void setup()
// initialize GDB stub
debug_init();
pinMode(LED_BUILTIN, OUTPUT);
void loop()
delay(1000);
delay(1000);
and when I ran the debugger, it works. This project was made in PlatformIOs default location, as opposed to my own project in which I set the location manually. I tried migrating my own code to this new project, and when I ran it, I got the same error shown above. I don’t know what’s causing the issue, and I would appreciate any help you can give me. Here’s the code I’m trying to debug (I’ve modified it a bit so you know what’s happening within functions):
unsigned int curMS;
#define MAIN_ENABLE
#ifdef MAIN_ENABLE
int main(void){
debug_init();
//The code below is called from a function in a board_init library i wrote
CLKPR = 0b10000000; //raise prescaler change enable bit
CLKPR = 0b00000011; //set prescaler to 8 to run at 2MHz
SREG |= (1<<7); //enable global interrupt
//the code below is called from a function in my timer library
TCCR2A = 0b00000010; //clear timer on compare match
TCCR2B = 0b00000010; //prescaler to 1:8
TCNT2 = 0; //initialize timer
OCR2A = 0xFA; //output compare to 250
ASSR = 0; //clear asynch settings
TIMSK2 = 0b00000010; //interrupt enable for T2A
msCount = 0;
// the onboard LED corresponds to PORT B, pin 7
// set the DataDirectionRegister of PC3 as input
DDRB = 0xFF; // set data direction to output
DDRA = 0x07; // set columns to output
PORTB = 0x00;
flag = 2000;
curMS = 0;
while (1){
//SETBIT(PORTB, 7);
curMS = Get_Milliseconds();
if (curMS > 0){
SETBIT(PORTB, 7);
return(0);
Quick note for understanding, my timer library contains an interrupt which triggers every millisecond. msCount increments each time the interrupt is triggered, and Get_Milliseconds() simply returns msCount.
Apologies if I’m missing any info, please ask about anything that you’re curious about. Thanks for the help.
