Can't debug arduino Uno in C (avr-stub)
Here’s my platformio.ini
[env:uno]
board = uno
debug_tool = avr-stub
debug_port = COM6
    jdolinay/avr-debugger
and the code that works
#include <avr8-stub.h>
#include "app_api.h"
      debug_init();
      pinMode(LED_BUILTIN, OUTPUT);
   delay(500);
   delay(500);
When I renamed the file to .C extension, and its content to
 * Copyright (C) PlatformIO <contact@platformio.org>
 * See LICENSE for details.
#include <avr/io.h>
#include <util/delay.h>
int main(void)
    debug_init();
    // make the LED pin an output for PORTB5
    DDRB = 1 << 5;
    while (1)
        _delay_ms(500);
        // toggle the LED
        PORTB ^= 1 << 5;
    return 0;
It fails to start debugging, with following message:
Reading | ################################################## | 100% 0.67s
avrdude: verifying ...
avrdude: 4744 bytes of flash verified
avrdude done.  Thank you.
========================= [SUCCESS] Took 3.88 seconds =========================
Reading symbols from D:\embedded\test\.pio\build\uno\firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
2
Bogus trace status reply from target: timeout
Related thread
I didn’t not change clock rate as author did, but I’ve tried to set BAUD rate in platformini.io to 115200 and it did not help.
Remove that line to disable compilation of the Arduino core if you’re going to do baremetal / avr-libc programming.
Can you then test the canonical example
with the include path fixed up?
It worked, looks like
breakpoint();
was required to be added. Ty
Would debug_message work on an arduino nano ?
is it somehow possible to debug an avr target (without usb serial connection) from say an arduino nano host ? possibly something that you can upload to run on the target avr ?
If it’s not working it’s a bug.
Well, if you can upload a sketch that is avr-stub enabled to your target AVR microcontroller, then the tooling doesn’t care how you get the UART communication between your PC and the target AVR microcontroller working. You could use a an Arduino Nano as a serial-to-USB bridge. Just like a more approriate serial-to-USB converter like an FT232 or CH340 etc.
The other way to go (that’s also way more professional) is to build a AVR debugger probe that connects to the target AVR microcontroller via debugWire on the RESET pin. Newer AVRs use other debugging protocols like PDI or UPDI. See https://pyavrocd.io/supported-debuggers/.
