hi, max, here’s some output you may want to see:
Processing esp32dev (platform: espressif32; framework: espidf; board: esp32dev)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.3.1) > Espressif ESP32 Dev Module
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210114 (8.4.0)
WARNING: You are using pip version 21.2.4; however, version 21.3 is available.
You should consider upgrading via the 'c:\users\krembuk\.platformio\penv\scripts\python.exe -m pip install --upgrade pip' command.
Found 0 compatible libraries
Compiling .pio\build\esp32dev\app_update\esp_app_desc.o
Archiving .pio\build\esp32dev\esp-idf\app_update\libapp_update.a
Generating project linker script .pio\build\esp32dev\esp32.project.ld
warning: the int symbol SPIFFS_BASE_ADDR (defined at C:/Users/krembuk/Documents/PlatformIO/Projects/TTGO/components/spiffs/Kconfig:3) has a non-int default 0x180000 (undefined)
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 7.0% (used 22948 bytes from 327680 bytes)
Flash: [== ] 23.4% (used 245352 bytes from 1048576 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v3.1
Merged 1 ELF section
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM4
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v3.1
Serial port COM4
Connecting.......
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 84:cc:a8:60:91:d0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00001000 to 0x00007fff...
Flash will be erased from 0x00010000 to 0x0004bfff...
Compressed 25232 bytes to 15290...
Writing at 0x00001000... (100 %)
Wrote 25232 bytes (15290 compressed) at 0x00001000 in 0.8 seconds (effective 258.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 118...
Wrote 3072 bytes (118 compressed) at 0x00008000 in 0.1 seconds (effective 345.4 kbit/s)...
Compressed 245456 bytes to 142033...
Writing at 0x00010000... (11 %)
Writing at 0x00018f6d... (22 %)
Writing at 0x00021647... (33 %)
Writing at 0x00026abe... (44 %)
Writing at 0x0002c0ab... (55 %)
Writing at 0x000317d9... (66 %)
Writing at 0x0003adf3... (77 %)
Writing at 0x00042762... (88 %)
Writing at 0x00047e4e... (100 %)
Wrote 245456 bytes (142033 compressed) at 0x00010000 in 3.6 seconds (effective 541.2 kbit/s)...
Leaving...
Hard resetting via RTS pin...
================================================================================ [SUCCESS] Took 114.72 seconds ================================================================================
Here’s the SPIFFS upload
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-ninja 1.9.0
esptool.py v3.1
Auto-detected: COM4
esptool.py v3.1
Serial port COM4
Connecting.......
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Changed.
Leaving...
