[SOLVED] ESP32 Serial monitor not working
I can build and upload the programs on my ESP32.
But when I run the Monitor Serial nothing happens and the LED stops blinking (the port and the baudrate are good)
I tried VS Code with PlatformIO and Sublime Text with Deviot same problems. While on the Arduino IDE everything is ok.
If anyone has a solution ? :slight_smile:
Could you reproduce this issue with a simple main.cpp?
  Serial.begin(9600);
  Serial.println("Test");
void loop () {
I just tried nothing, I try on another pc even worries, the problem could come from the ESP32
https://youtu.be/F9Y5JsHHvoc
Does it work with Arduino IDE?
Yes, I have just found the trouble, just put Off DTR & RTS in the settings of the serial monitor.
Zh0nd, how can I do it?
This is documented in Redirecting....
It works for me
adding to platformio.ini monitor_speed = 115200
monitor_rts = 0
monitor_dtr = 0
Thanks a lot!
this solution worked like a charm.
The serial monitor worked on the Arduino IDE, but not on the VC Code IDE.
This change fixed the problem.
I didn’t seem to need the monitor_dtr = 0
Thanks
For anyone else struggling with similar issues when working with custom ESP32-based hardware without an external USB-to-UART bridge, using only the native USB port built into the MCU, the following platformio.ini configuration worked for me.
I am using the ESP32-C3FH4X.
[env:esp32-c3-devkitm-1]
board = esp32-c3-devkitm-1
    -DARDUINO_USB_MODE=1
    -DARDUINO_USB_CDC_ON_BOOT=1
upload_port = COM6
monitor_port = COM6
