Since I dont have any 3D printer, in particular also no SKR 1.4 Turbo, I can’t dump the firmware image.
My suggestion would be to try to program the board with a simple program to check whether the chip is working okay, e.g. with an Arduino sketch. That sketch can then also check if it can read an SD card. So thus you might get closer to the actual problem (if it isn’t that the burned bootloader is wrong after all).
PlatformIO natively doesn’t support the LPC1769 chip though in the platform, only LPC1768 and other. But custom support is available.
I have trouble expressing myself initially, the printer worked before I flash with “Flash Magic”
I just wanted to make a modification
as I could no longer flash with the firmware.bin in the micro sd, I thought that the bootlader was overwritten
but I don’t think the LPC 1769 is dead I just tested another bootloader that someone put on github ==> [GUIDE] No update from SD solution? · Issue #423 · bigtreetech/BIGTREETECH-SKR-V1.3 · GitHub and the problem is the same
anyway thank you for your help and sorry for my english “google translate”
Flashmagic also works with .bin files. The PlatformIO Marlin build will output that .bin file (in .pio\build\<environment>\firmware.bin), which you may attempt to flash. See my text in SKR 1.4 Turbo Motherboard Without SD-CARD Reader! Bricked? - #4 by maxgerhardt regarding the bootloader and possible offset address which might not make this work.
I have started a repo of all BIGTREETECH bootloaders. I have ripped them from the boards I own. If I do not have the board I will get one in. But while I wait for boards I have found bootloaders on the web.
I hope this resource is helpful:
I have also provided manual on how to backup and restore bootloader/Marlin firmware:
Such a great topic with awesome solutions. I’m currently looking into fixing an SKR 1.4 with a broken MicroSD card reader. I tried to desolder the old one by hand but the last pin pulled the contact with it clean off of the board. Now I found out this pin actually wasn’t used, and that’s probably the reason why it just came off. I also see in pictures above that the other user had this exact same issue.
Ordered both a SPI MicroSD card reader and a replacement MicroSD slot, identical to the original one. So I’ll wait for that one to arrive first and then try to fix the board. If I don’t manage I’ll go the SPI route.
On another board (I received two broken boards from a student of mine, to repair and keep), the card gives an error when connected through USB, it’s not recognized. So I tried flashing the firmware with an FTDI programmer, but it tells me it cannot connect through the COM port with set baud rate. So I’ll have to tinker some more with that one later but I think it’s really dead dead.
There was a lot of info in this topic that cannot be found anywhere else on the web so I’m very grateful for this. Just one thing, I would like to know if the SPI route with the external slot solved the problem, it wasn’t clear to me if the user got it to work.
Ah, thanks, I had seen the topic, but only saw the opening post. Now I realize he updated saying it did indeed work and that the SKR needed a reboot in order for it to function. Good to know!
