I created a custom framework-ardunioespressif32 with some tweaked settings to be able to put some big buffers into PSRAM, following recommendations from other posts, e.g. Custom ESP32 Arduino libraries build and Correct settings to enable external RAM on ESP32.
Now that I have successfully built the libraries, I created a repository so I can reference it in my platformio.ini
. Unfortunately I get the following error:
Resolving trainboard dependencies…
Error! Failed to extract upstream toolchainconfigurations:
Extra data: line 1 column 4 (char 3)
Here is my platformio.ini
[env:my_project]
board = esp32-s3-devkitc-1
extra_scripts = build/prebuild.py # Just modifying some text files here
monitor_rts = 0
monitor_dtr = 0
-D ARDUINO_USB_CDC_ON_BOOT
-DCORE_DEBUG_LEVEL=4
-std=gnu++17
-Wl,-Map,output.map
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-DCONFIG_SPIRAM_CACHE_WORKAROUND=1
-Ibuild/
-Isrc/
-Isrc/Database
-Isrc/Interfaces
-Isrc/Led
-Isrc/StateMachine
-Isrc/Util
-Ivendor/etl/include
build_unflags =
-std=gnu++11
fastled/FastLED@^3.5.0
https://github.com/tzapu/WiFiManager/archive/refs/tags/v2.0.17.zip
platform_packages =
framework-arduinoespressif32 @ https://github.com/edautomation/framework-arduinoespressif32.git
Did I make some mistake? What did I miss?
Any help would be greatly appreciated
