I did review this post https://community.platformio.org/t/serial-monitor-always-print-nul-in-vs-code/16173/11, and I was going to comment on it but then decided against it. It’s an older post, and it seems to have been answered. I didn’t want to hijack that post. Since the solution did not work, I figured it be better to open a new post.
This is the first time using PlatformIO. I have a ESP32-CAM board that I have attached to my MacBookPro. I have no problems building and uploading to the board. However, when I view the serial monitor, all I receive is a run on of “Nul” (‘NUL’ not ‘Null’). I have verified the baud rate. I have tried several other baud rates just for testing purposes. Again, all I receive is ‘Nul’ in the serial monitor.
The strange thing is, as the other post states, it works fine in Arudino IDE. I have tried uploading the program from Arduino IDE and then viewing the serial monitor in PlatoformIO. I receive the NUL. I have tried uploading the program from PlatformIO and then viewing the serial monitor in Arduino IDE with no problem. The serial monitor works perfectly.
Microsoft now has a new extension called “Serial Monitor” Serial Monitor - Visual Studio Marketplace, and I also receive Nul.
I’m wondering if it has something to do with VSCode?
I also tried, as per the other post, moving the pinMode above the Serial.begin, with no effect on the serial monitor. I still receive ‘Nul’.
Any suggestions and or guidance would be greatly appreciated. Thank you!
MacBookPro
Monterey Version 12.6 (I have not updated to 13 due to the Raspberry Pi Pico “Finder” problem)
VSCode
Version: 1.73.1 (Universal)
Commit: 6261075646f055b99068d3688932416f2346dd3b
Date: 2022-11-09T02:08:38.961Z
Electron: 19.0.17
Chromium: 102.0.5005.167
Node.js: 16.14.2
V8: 10.2.154.15-electron.0
OS: Darwin x64 21.6.0
Sandboxed: No
PlatformIO
Core: 6.1.5
Home 3.4.3
Arduino IDE
**Version: 2.0.1
Date: 2022-10-27T13:25:59.041Z
CLI Version: 0.28.0 [06fb1909]
Hardware
ESP32-CAM
platformio.ini
[env:esp32cam]
board = esp32cam
main.cpp
* OnDemandConfigPortal.ino
* example of running the configPortal AP manually, independantly from the captiveportal
* trigger pin will start a configPortal AP for 120 seconds then turn it off.
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
// select which pin will trigger the configuration portal when set to LOW
#define TRIGGER_PIN 4
int timeout = 120; // seconds to run for
WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
// Placed pinMode above Serial.begin per previous post
pinMode(TRIGGER_PIN, INPUT_PULLUP);
Serial.println("\n Starting");
// is configuration portal requested?
if ( digitalRead(TRIGGER_PIN) == LOW) {
WiFiManager wm;
//reset settings - for testing
//wm.resetSettings();
// set configportal timeout
wm.setConfigPortalTimeout(timeout);
if (!wm.startConfigPortal("OnDemandAP")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.restart();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
Update: I decided to try it on my Raspberry Pi 4. I install PlatformIO CLI on the Rasp 4. I connected the ESP32-CAM to the Rasp 4 and ran the command pio device monitor -b 115200. Same thing happens. I get a run on of ‘Nul’. Seem to be something to do with PlatoformIO. Again, I tried again with Arduino IDE and the Arduino IDE serial monitor works perfectly.
