Looking for an expert to clarify something - the documentation states
Seeed Studio XIAO ESP32C3 does not have on-board debug probe and IS NOT READY for debugging. You will need to use/buy one of external probe listed below.
However the chip has on-chip JTAG and the serial pins are directly connected to the USB port. Is this a chip issue or a board issue or a PlatformIO support for this board issue?
The ESP32-C3 contains an USB Serial/JTAG Controller. This unit can be used to program the SoC’s flash, read program output, as well as attach a debugger to the running program. All of these are possible for any computer with a USB host (’host’ in the rest of this text) without any active external components.
I don’t understand why Seeed would blow the JTAG fuse, it makes no sense.
Here is the error message when I try to upload and run the debugger. NOTE I am using default esp-tool for upload, not debugger. My first thing to confirm is that platformIO integrated debugging should work without esp-prog (ie, everything I see says on-chip JTAG should work…). Or maybe I’m missing something - but the debug build and download work fine…
Reading symbols from /home/tony/ESPprojects/ESP32c-Switch/.pio/build/seeed_xiao_esp32c3/firmware.elf…
PlatformIO: debug_tool = cmsis-dap
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read OpenOCD: Bug Reporting
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: unable to find a matching CMSIS-DAP device
Error: Unsupported xlen: -1
Error: Unknown target arch!
Remote communication error. Target disconnected.: Connection reset by peer.
Thanks for finding this! I’m going to try to set the platformio settings per the example - I assumed that the board type setting would make these automatic but who knows? I’ll come back with what I find.
The good news is that it’s connecting.
First time - got an error about protection - per tutorial I hit the reset button and restarted the debugging. Now I always get these errors. What are the USB build flags you are using? I’ll add those and see if it makes a difference.
This is just to route the output of Serial.println to the USB Serial (HWCDC).
Without them there won’t be any output on my serial interface because I use the esp32-c3-devkitm-1 in my platformio.ini.
LOL. Nope you can’t, the paste didn’t paste. Changing the build flags forced a complete rebuild so I can start from scratch. I’ll try to paste properly, thank you for your help.
First off - the platform server list in platformio.ini is directly in the tutorial you sent me so I just cloned it. It seems to me that by specifying the board type explicitly I should not need any of these things, but here we are :-).
Here is the error output (hope I paste this correctly)… From the first run. After this per the tutorial I press reset on the board and try to reattach. Similar result.
Reading symbols from /home/tony/ESPprojects/ESP32c-Switch/.pio/build/seeed_xiao_esp32c3/firmware.elf...
PlatformIO: debug_tool = esp-builtin
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Warn : Transport "jtag" was already selected
Info : esp_usb_jtag: serial (64:E8:33:86:10:88)
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 5000 kHz
Error: libusb_bulk_write error: LIBUSB_ERROR_IO
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Error: missing data from bitq interface
Error: failed jtag scan: -104
Error: Unsupported DTM version: 8
Warn : target esp32c3 examination failed
Info : starting gdb server for esp32c3 on pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32c3:
Warn : No symbols for FreeRTOS!
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
Here is my platformio.ini incl my build flags for wifi (which is blowing up inside WiFi.begin with an unhandled exception, which is what started this mess…)
It still failed. So I got another board - and it’s entering debug. Bizarre. There must be some sort of defect on that chip - but the program is running with my print statements, it just wouldnt go into debug.
Can you tell me what the “@6.9.0” version of the framework is or point me to some references now that I’m about to start debugging the original wifi problem I hit…
Oh - the platformIO document that says this board only will work with an external JTAG - not sure who owns that. I think I found an errata somewhere that implied the first spin of the chip had a JTAG problem - maybe(?) , and maybe one of my boards has one of those??? IDK but just my luck
Interesting… the 2nd board is now in the same state as the first board. I started a debug session stepping over “serial.begin” and I got an error “duplicate breakpoint” and when I forced break it seems to be in an endless loop - tried to restart the debug session and now this board is dumping the same errors as the first one - the error dump looks the same. Very strange. Any ideas appreciated as I start banging away on this…
Just a suggestion, I recently acquired an esp32c3 dev board and installed the esp32-idf plugin to vscode which contained a custom openocd for the esp32c3 jtag which I can confirm works although I’m still in the process of finding memory dump and manipulation functions which I’m sure are there somewhere. So possibly the actual answer is to install the esp32-idf sdk.
sorry my bad, I installed platformIO for the ch32v003 and used the vscode esp32-IDF plugin for the development of the esp32C3. I wasn’t aware of the incompatibility with arduino
Unfortunately I had to stop my session and didn’t capture the dump. However, saw the LIBUSB errors etc - it looked like it was the same relative fail mode.
I was using a RPi5 to do a “quick” wifi test, which is blowing up somewhere in the wifi module of the arduino framework and was trying to do a quick debug traceback to see where - nothing has been “quick” so far ;-). Now I think I also need to figure out if the arduino framework will work for for wifi on this board. I am also now wondering if the Pi5 is not fast enough to run the debug or has enough memory to do the debugging, so I’m going to find another computer to try this on again… I’ll post back when I have time to make more progress on it.
