Is there a way to register not only new libraries, but also platform and framework?
Generally speaking, I also expected that it should not be needed to create a new platform for this (as the underlying one is atmelavr), so I expected that only a framework is enough. However, I have not found a way to add a new framework and allow existing boards to use it without modifying the board definitions in the atmelavr platform board files?
I wasn’t aware that adding root only is enough - will try it out
It should be possible to create macros on-the-fly, but:
It should generally be easier to maintain the macro mapping in .h rather than .py, and the general split of responsibilities between basic build scripts and board-specific mappings seems clearer this way
I would expect that updating build scripts should not be needed while adding support for new boards
That said, I have a couple of clarifying questions:
3) I’ve managed to eliminate the need to define a new platform, so platform=atmelavr can readily be used in combination with framework=cosa (readme with instructions added to Git). However, adding a new framework seems to affect the underlying platform package: a) it’s platform.json needs to be updated to introduce the new framework as supported, and b) all board.json files need to be updated as well. How do you manage these inter-package dependencies in terms of release alignment? E.g. if the framework adds support for lets say attiny8x - this needs to be reflected in a new platform release too?
