I was working on an Arduino project and when I wanted to build it, it took a long time before PlatformIO started building it and it was the same for uploading.
What environment do you have? (IDE + version, platformio version, build times / logs, operating systemā¦)
Any antivirus active on the system? Does make it a difference when itās off?
Iām using vscodes version 1.42.1, my platformIO version is 1.10.0 and Iām on windows 10.
I havenāt used any antivirus software neither have one currently installed.
Whats your platformio.ini?
Iām sorry what do you mean by that?
The project for which building is slow, whatās the content of itās platformio.ini file? Itās the main configuration file in the project folder.
;PlatformIO Project Configuration File
[env:megaatmega2560]
board = megaatmega2560
Open a PIO terminal.
Then press enter once in the shell and run
pio run -t clean
pio run
Does some output appear immedeately if you execute the last pio run command? Is it faster compared to executing āCleanā and āBuildā via the VSCOde project task list?
Yes and itās faster compared to running build via the task list.
Well then the issue somewhere within VSCode or the plugin and PIO compilation itself is working perfectly fine. I suggest to reinstall the VSCode PIO extension. If you want to nuke your entire previous PlatformIO installation you can also remove the C:\Users\<user>\.platformio folder.
Thanks I will try that.
+1 For this also⦠the responsiveness of building in VSCode on Windows 10 seems to have taken a real nosedive in the last several weeks⦠Iām unclear as to whether it is VSCode, my anti-virus (Bitdefender 2020), or Windows 10 gone berko though⦠I tend to think it is VSCode as it seemed to get worse after the 1.42.x update⦠And I have once again gone back to Linux for anything ācompileā related as VSCode + PlatformIO is working great there, as is just so fast⦠compiling and uploading to a Pro Micro without a DTR line connected (i.e. needing manual reset) is almost too fast there⦠barely have enough time between pressing ābuild and uploadā and being able to fumble for that reset button so the upload can happen!
I now occasionally get complete lockups from VSCode when trying to build and upload and it sometimes takes several seconds to actually start a task. It is responsive in starting from the CLI, but compile speed is slow - the normal just Windblows standard + AV sluggishness/laggyness.
Edit: Also, Iām often getting the syntax highlighting corruption someone else recently mentioned, again on Windows only⦠have to swap to another tab and back again to get it to render properly.
Thank you. reinstalling platformIO worked
