Environment: Windows 10 + VS Code with PlatformIO addon.
PlatformIO IDE messes up the PATH environment variable which causes that I am unable to run the pio command in the PlatformIO IDE in terminal window.
Over time my .platformio folder has grown to more than 6 GB in size eating up valuable space on my Windows system drive. To free up space I recently moved the .PlatformIO folder from C:\Users\<user>\.platformio to D:\Users\<user>\.platformio.
I read that I had to set environment variable PLATFORMIO_CORE_DIR and let it point to the new folder to make PlatformIO aware of the new location. I also read that I had to update file .vscode\c_cpp_properties.json in each of my projects and replace the old path with the new (to prevent any error messages). I did both.
I also updated my (user) PATH environment variable which contained C:\Users\<user>\.platformio\penv\Scripts;C:\Users\<user>\.platformio\penv. I changed the drive letters in both folder paths from C: to D:
For a while everything appeared to work fine, until I wanted to use the pio command in VSCode terminal window again (for the first time in the new situation). I got the following error:
pio: The term ‘pio’ is not recognized as a name of a cmdlet, function, script file, or executable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Outside of VSCode/PlatformIO IDE I can run the pio command just fine because the penv and Scripts folders are included in PATH but within the IDE in a terminal window it does not work.
After doing some tests I noticed that the PlatformIO IDE messes up the PATH environment variable. It removes the correct
D:\Users\<user>\.platformio\penv\Scripts;D:\Users\<user>\.platformio\penv
from my PATH and inserts
somewhere at the beginning of the PATH instead which causes the problem. These folders do not even exist because everything is on drive D:.
I checked the PlatformIO settings in VSCode but could not find find any occurrence of C:\Users\<user>\.platformio that I could update.
Questions
Why stealthly modify the PATH environment variable and why remove already present correct values?!
Why force apparently (incorrect) hard coded values instead of using the correct folder paths? Is this a bug in PlatformIO?
There is no need to make changes to the PATH environment variable without consent and the correct paths can be easily determined from the value of
PLATFORMIO_CORE_DIR. -
How to fix this?
