PlatformIO Core upgrade from 6.1.18 to 6.1.19 not working
When I try to update PlatformIO Core to version 6.1.19 there aren’t any errors but it stays on 6.1.18, here is the output from the PlatformIO CLI:
>platformio --version
PlatformIO Core, version 6.1.18
>pio upgrade
Please wait while upgrading PlatformIO Core ...
PlatformIO has been successfully upgraded to 6.1.18
Release notes: https://docs.platformio.org/en/latest/history.html
Warning! Please restart IDE to affect PIO Home changes
I am using PlatformIO with VS Code:
Version: 1.128.0 (system setup)
Commit: fc3def6774c76082adf699d366f31a557ce5573f
Date: 2026-07-07T15:14:24-07:00
Electron: 42.5.0
ElectronBuildId: 14525058
Chromium: 148.0.7778.271
Node.js: 24.17.0
V8: 14.8.178.33-electron.0
OS: Windows_NT x64 10.0.19045
See Troubleshooting — PlatformIO latest documentation
Please remove multiple installations of PIO Core.
I don’t think I have multiple installations of PIO Core. Is there a way to check if multiple PIO Cores are installed on the system?
platformio-ide.useBuiltinPIOCore is already set to true.
Could you try manually removing ~/.platformio folder and restarting VSCode?
I am sorry for the late reply. As I am in the middle of updating some older projects to compile them with the new framework I will, as soon as I catch time, try to reproduce the problem in a virtual machine - not to break the existing environment.
But, as you have already documented, the problem is because pioarduino platform compromises the Platformio core.
