PlatformIO Core 6.1.19 is out!
- Added support for Python 3.14
- Upgraded the Doctest testing framework to version 2.4.12, the GoogleTest to version 1.17.0, and the Unity to version 2.6.1, incorporating the latest features and improvements for enhanced testing capabilities
- Enhanced compatibility with the CCLS language server, improving integration with editors like Emacs, Sublime Text, and Vim (issue #5186)
- Improved error messages for package installation to make it easier to understand when a package is missing or incompatible (pull #5336).
- Fixed a regression issue where custom build flags were not properly reflected in the compile_commands.json file, ensuring accurate compilation database generation
- Fixed an issue where fully-qualified serial port URLs (e.g.,
rfc2217://host:port) were incorrectly treated as wildcard patterns (issue #5225) - Fixed an issue where the toolchain path in static analysis was not handled correctly if it contained spaces (pull #5351)
- Fixed installation failure when the executable path contains spaces for
postinstallscripts and handling both list and string command formats (pull #5366) - Fixed cleanup of the
.pio/libdepsfolder so that leftover libraries are properly removed when the lib_deps option is empty (issue #5110)
See PlatformIO 6.1.19 Release Notes for details.
Upgrade
- PlatformIO IDE: Left Sidebar > PlatformIO (icon) > Quick Access > Upgrade PlatformIO Core
- Terminal: Please run the
pio upgradecommand in the terminal.
Regards,
Your friends at PlatformIO
