but when I click upload, it tries to upload an Arduino Uno hex firmware file to the Arduino Pro Micro, even when it’s the only device plugged in. How can I correct this? If I uncomment the line above, it uploads to the Pro Micro, but that’s not a sustainable solution.
Is this when you click the main ‘Build’ option, instead of the environment specific one? As if that is the case, when you have multiple environments configured, unless you set a default, they will ALL build/upload when you hit the main Build/Upload option. btw, spaces in the environment name didn’t seem to be an issue here.
And this is when you hit the Upload option specifically for the sparkfun promicro16 environment? As I can’t really tell which build environment that was for as you snipped the top bit… the very first line of the output is quite important.
It should look more like this… (note, no device plugged in, and see that the uno environment was skipped)…
Processing sparkfun promicro16 (platform: atmelavr; board: sparkfun_promicro16; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sparkfun_promicro16.html
PLATFORM: Atmel AVR > SparkFun Pro Micro 5V/16MHz
HARDWARE: ATMEGA32U4 16MHz 2.50KB RAM (28KB Flash)
Collected 24 compatible libraries
Checking size .pioenvs/sparkfun promicro16/firmware.elf
DATA: [= ] 5.8% (used 149 bytes from 2560 bytes)
PROGRAM: [= ] 12.6% (used 3618 bytes from 28672 bytes)
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
Looking for upload port...
Auto-detected: /dev/ttyACM0
Forcing reset using 1200bps open/close on port /dev/ttyACM0
Waiting for the new upload port...
Uploading .pioenvs/sparkfun promicro16/firmware.hex
Connecting to programmer: .
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "S"; type = p
Software Version = V.; Hardware Version = v.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
*** [upload] Error 1
=============================================== [ERROR] Took 22.28 seconds ===============================================
======================================================== [SUMMARY] ========================================================
Environment uno [SKIP]
Environment sparkfun promicro16 [ERROR]
Whereas you get this if you try to build/upload the uno environment… (and this time skipping the promicro16)…
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR > Arduino Uno
HARDWARE: ATMEGA328P 16MHz 2KB RAM (31.50KB Flash)
Checking size .pioenvs/uno/firmware.elf
DATA: [ ] 0.4% (used 9 bytes from 2048 bytes)
PROGRAM: [ ] 1.4% (used 444 bytes from 32256 bytes)
AVAILABLE: arduino
Uploading .pioenvs/uno/firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
================================================ [ERROR] Took 2.21 seconds ================================================
Environment uno [ERROR]
Environment sparkfun promicro16 [SKIP]
Yes, those respective outputs are generated when I click the Upload buttons for the individual targets. When I use the upload keyboard shortcut, Ctrl + Alt + U, the following happens:
Collected 6 compatible libraries
Compiling .pioenvs\uno\src\main.cpp.o
Archiving .pioenvs\uno\libFrameworkArduinoVariant.a
Compiling .pioenvs\uno\FrameworkArduino\CDC.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial3.cpp.o
Indexing .pioenvs\uno\libFrameworkArduinoVariant.a
Compiling .pioenvs\uno\FrameworkArduino\IPAddress.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\Print.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\Stream.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\Tone.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\USBCore.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\WInterrupts.c.o
Compiling .pioenvs\uno\FrameworkArduino\WMath.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\WString.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\abi.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\hooks.c.o
Compiling .pioenvs\uno\FrameworkArduino\main.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\new.cpp.o
Compiling .pioenvs\uno\FrameworkArduino\wiring.c.o
Compiling .pioenvs\uno\FrameworkArduino\wiring_analog.c.o
Compiling .pioenvs\uno\FrameworkArduino\wiring_digital.c.o
Compiling .pioenvs\uno\FrameworkArduino\wiring_pulse.S.o
Compiling .pioenvs\uno\FrameworkArduino\wiring_pulse.c.o
Compiling .pioenvs\uno\FrameworkArduino\wiring_shift.c.o
Archiving .pioenvs\uno\libFrameworkArduino.a
Indexing .pioenvs\uno\libFrameworkArduino.a
Linking .pioenvs\uno\firmware.elf
Building .pioenvs\uno\firmware.hex
Checking size .pioenvs\uno\firmware.elf
DATA: [= ] 9.9% (used 202 bytes from 2048 bytes)
PROGRAM: [= ] 6.2% (used 2000 bytes from 32256 bytes)
AVAILABLE: arduino
Auto-detected: COM10
Uploading .pioenvs\uno\firmware.hex
^Cscons: *** [upload] Build interrupted.
Error: Aborted by user
I terminated it once I realized it was uploading the wrong file.
If you had left it, it would have failed, and then moved on to building and uploading the promicro16 environment.
When you have multiple environments configured, unless you set a default, they will ALL build/upload when you hit the main Build/Upload option (which includes using the keyboard shortcut). PIO is doing exactly what you have told it to do… it is attempting to build and upload both environments (in sequence).
Do what Ivan said. For some background, what he’s saying (and I hadn’t realised at the time) is that platformio does try to actually work out which of the connected devices is your Uno or Pro Micro, etc, etc, and then flash that device, rather than just the first one it comes across. It does this via the PID/VID (product and vendor IDs) identifiers the device offers up to identify itself to the computer. Since platformIO isn’t working out which of the boards is the pro micro, yours may have a different PID/VID, so if it doens’t clash with another board, it can be added so it can be automagically detected when you have both an uno and pro micro connected (without having to use the 'upload_port" parameter in your platformio.ini, and deal with it potentially changing…)
So, uh, the thing is that I haven’t been able to get to a terminal that recognizes a pio command. Even if I click on the icon for the terminal in the status bar, I still can’t get to a shell that is configured properly. Is there another way I can fetch this information for you?
YOU BROKE THE TERMINAL… HOW COULD YOU DO SUCH A THING?!
On more more serious note, does Ctrl+Shift+P and >platformio: new terminal (you should be able to start typing ‘term’ and let autocomplete find it…) work or is it just as non-cooperative?
Yep, that terminal is unresponsive. It doesn’t recognize the pio command. Might I need to use powershell as my terminal for this to work? I’m currently using WSL.
Out of curiosity, if you instead declare it to be a micro (as in Arduino Micro) as opposed to the sparkfun promicro16? Since the board is being detected as a Arduino Micro, and they seem to be essentially the same other than for colour and layout… go with the flow it if automagically works it out?
