I was trying to use the Adafruit_SSD1306 library in a Pico project but it gets the following error (full build output below):
.pio\libdeps\pico\Adafruit SSD1306\Adafruit_SSD1306.cpp:42:10: fatal error: pgmspace.h: No such file or directory
Apparently this is not needed for 32-bit devices and can be commented out but I’m trying to avoid modifying the library and I don’t get this error for the pico using the Arduino IDE.
I have found a compatible header here: ArduinoCore-sam/pgmspace.h at master · arduino/ArduinoCore-sam · GitHub
And added it to the include folder include/pgmspace.h and added it to build_flags in platformio.ini as follows:
[env:pico]
platform = raspberrypi
board = pico
adafruit/Adafruit SSD1306@^2.5.4
ppedro74/SerialCommands@^2.2.0
build_flags = -I pgmspace.h
However this line doesn’t seem to affect the output, I still get the same error / missing file:
I have tried to make the build log more verbose, but I’m not seeing anything in the output that confirms it’s loaded this included header.
Is it supposed to work this way (e.g. loading a header so a library can use it)?
I’m new to platform io - this project works in the arduino IDE with the rp2040 board.
Build output:
> Executing task in folder fstq-pro-proto1: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe run <
Processing pico (platform: raspberrypi; board: pico; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/pico.html
PLATFORM: Raspberry Pi RP2040 (1.7.0) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 3.1.1
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 42 compatible libraries
|-- Adafruit SSD1306 @ 2.5.4
| |-- Adafruit GFX Library @ 1.11.2
| | |-- Adafruit BusIO @ 1.11.6
| | | |-- Wire
| | | |-- SPI
| | |-- Wire
| | |-- SPI
| | |-- Wire
| | |-- SPI
| |-- Wire
| |-- SPI
|-- SerialCommands @ 2.2.0
| | |-- Wire
| | |-- SPI
| |-- Wire
| |-- SPI
|-- Fd_tm1638
|-- SPI
|-- Wire
Compiling .pio\build\pico\src\fsmp_throttle_pro_io.cpp.o
Generating LD script .pio\build\pico\cpp.linker_script.ld
Compiling .pio\build\pico\libf28\Wire\Wire.cpp.o
Compiling .pio\build\pico\lib4b9\SPI\SPI.cpp.o
Compiling .pio\build\pico\lib512\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Compiling .pio\build\pico\lib512\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\pico\lib512\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\pico\lib4c3\Adafruit GFX Library\Adafruit_GFX.cpp.o
Compiling .pio\build\pico\lib4c3\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Compiling .pio\build\pico\lib4c3\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
Archiving .pio\build\pico\lib4b9\libSPI.a
Archiving .pio\build\pico\libf28\libWire.a
Compiling .pio\build\pico\lib4c3\Adafruit GFX Library\glcdfont.c.o
Compiling .pio\build\pico\libfcb\Adafruit SSD1306\Adafruit_SSD1306.cpp.o
Compiling .pio\build\pico\lib53a\SerialCommands\SerialCommands.cpp.o
Compiling .pio\build\pico\liba1d\Fd_tm1638\Fd_tm1638.cpp.o
Compiling .pio\build\pico\liba1d\Fd_tm1638\Fd_tm16xx.cpp.o
* Looking for pgmspace.h dependency? Check our library registry!
* CLI > platformio lib search "header:pgmspace.h"
* Web > https://registry.platformio.org/search?q=header:pgmspace.h
42 | #include <pgmspace.h>
compilation terminated.
Archiving .pio\build\pico\lib512\libAdafruit BusIO.a
*** [.pio\build\pico\libfcb\Adafruit SSD1306\Adafruit_SSD1306.cpp.o] Error 1
