Every project seems to trigger the message, even a new, unmodified project: VSCode -> PIO Home -> New Project -> click Build
Also, from the PIO CLI window in VSCode:
$ pio run -h **************************************************************************************************************************************************************************************************************
Obsolete PIO Core v5.1.0 is used (previous was 5.1.1a3)
Please remove multiple PIO Cores from a system:
Redirecting...
Also tried a verbose build on a new project, but I’m not sure it illuminated anything new:
$ pio run -v **************************************************************************************************************************************************************************************************************
https://docs.platformio.org/page/faq.html#multiple-platformio-cores-in-a-system
************************************************************************************************************************************************************************************************************** Processing mayfly (platform: atmelavr; board: mayfly; framework: arduino) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
CONFIGURATION: Redirecting...
PLATFORM: Atmel AVR (3.2.0) > EnviroDIY Mayfly
HARDWARE: ATMEGA1284P 8MHz, 16KB RAM, 127KB Flash
DEBUG: Current (simavr) On-board (simavr)
- framework-arduino-avr 5.1.0
- toolchain-atmelavr 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Found 5 compatible libraries
Scanning dependencies…
No dependencies
MethodWrapper([“checkprogsize”], [“.pio\build\mayfly\firmware.elf”])
Advanced Memory Usage is available via “PlatformIO Home > Project Inspect”
RAM: [ ] 0.1% (used 9 bytes from 16384 bytes)
Flash: [ ] 0.4% (used 510 bytes from 130048 bytes)
.pio\build\mayfly\firmware.elf :
section size addr
.data 0 8388864
.text 510 0
.bss 9 8388864
.comment 17 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 64 0
.debug_info 2314 0
.debug_abbrev 1873 0
.debug_line 258 0
.debug_str 662 0
Total 5771
======================================================================================== [SUCCESS] Took 0.64 seconds ========================================================================================
